Hey Phil.
There was a BIG misunderstanding,after i called u,i never got ur call back so i figured you forgot. (Now i know there was a miscommunication on my part).
I ended up fabricating some mounts from some c10 springs.
No i dont need the mounts anymore...
I had the money order ready just cashed to myself now.
Thanks for your time.
Hey Phil.
Thanks for the response. I didn't forget. Just after you called, family issues came up with our daughter and grand daughters to slow me down as well as the phone number issue.
For everybody else, I have the following parts for F1 48-52:
2 rear spring frame brackets
2 rear spring shackles with pins and lock pins
2 rear spring front pins and lock pins.
You can look for a spot weld on the bottom of the mid-rail that’s shows center of gravity. The forklift drivers use it here to pick stacks of frames to carry to the train yard. We ship the frames upside down so that’s why the spot weld is on the bottom. 🙏
