FUEL PUMP ?
Old Jun 14, 2015 | 04:40 PM
PAUL W BEAUCHEMIN's Avatar
PAUL W BEAUCHEMIN
FUEL PUMP ?
WHEN YOU RUN MECH. AND ELEC. FUELPUMPS DO YOU T IN ELEC. PUMP AFTER MECH. PUMP OR CAN YOU RUN THEM INLINE ? 51 F1 FLATHEAD THANKS PB
Old Jun 14, 2015 | 04:42 PM
pbsdaddy's Avatar
pbsdaddy
Just cap the line for the mechanical. Why would you run both? Why do you want to run both? maybe I don't understand.
Old Jun 14, 2015 | 04:47 PM
PAUL W BEAUCHEMIN
SOMETIMES THEY RUN ELEC. TO PRIME THEN SHUTOFF AND RUN ON MECH PUMP
Old Jun 14, 2015 | 04:51 PM
pbsdaddy's Avatar
pbsdaddy
Ok. Seems a bit redundant, but I understand.
I am running just an electric. With the mechanical still in place, most people don't know and don't notice the capped lines.
Old Jun 14, 2015 | 06:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Are you drawing out of the tank for the electric from a separate line than for the mechanical, or is the electric pump in the suction line for the mechanical?
Please don't use all Caps!
Old Jun 14, 2015 | 07:02 PM
PAUL W BEAUCHEMIN
I WANT TO RUN IT INLINE WITH THE MECH. BUT WILL MECH PUMP DRAW FUEL THROUGH THE ELEC.PUMP WHEN IT IS NOT RUNNING ? THANKS PB
Old Jun 14, 2015 | 07:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Some electric pumps can be drawn thru, others have pretty high resistance.
Old Jun 14, 2015 | 08:24 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Welcome to FTE!
If you look on your keyboard, there's a key labelled "Caps Lock". When you type in all capital letters, it's considered shouting. We'd love to help you, but we really don't like being yelled at.
Thank you.
Old Jun 15, 2015 | 07:17 PM
flattie39's Avatar
flattie39
When I was running a flathead in my 39, the fuel would siphon back into the tank overnight. I ran an electric pump at the tank connected in series with the mechanical pump up front. In the morning I would run the electric pump for about 15 seconds to refill the carb bowl - turn it off and crank and run the motor with the mechanical pump. Never had a problem and if one of the pumps quit, I could get home on the other. Ken
Old Jun 16, 2015 | 02:16 PM
PAUL W BEAUCHEMIN
yes I will try it in series I would like to thank all of you for your replies pb
Old Jun 16, 2015 | 03:21 PM
Jolly Roger Joe
Please keep us up to date on how it works for you. Others may want to do the same thing.
Old Jun 17, 2015 | 07:17 PM
abe's Avatar
abe
My 70 F350 had a electric fuel pump on when I bought it 2.5 years ago. The original fuel pump was in place. It worked fine. One day I removed the hot wire to the electrical pump and the mechanical pump worked fine drawing gas through the electrical pump.
Old Jun 20, 2015 | 10:06 AM
PAUL W BEAUCHEMIN
update fuelpump
ran my truck down the road today, mech. fuelpump sucks gas right up through the facet elec.pump down by the bottom of the gas tank and runs good, thanks pb
Old Jun 28, 2015 | 09:13 PM
artscott61's Avatar
artscott61
Veteran: Navy
WHATS THIS SHOUTING ALL ABOUT oops! sorry I had my hearing aids out I just had to do that
f1001969mike
1978 - 1996 Big Bronco
Sep 9, 2013 07:34 PM
XTfx4
Jun 5, 2013 01:21 PM
fixnair
Flathead V8 & Flathead 6
Dec 19, 2010 07:30 AM
Texan1983
Offroad & 4x4
43
Apr 26, 2008 02:51 PM
SamD
1947 and Older Ford Trucks
Mar 21, 2004 01:18 PM
