Electric fan controller
Old Jun 19, 2015 | 07:13 PM
eakermeld's Avatar
eakermeld
Originally Posted by quincyj34
How do you have the light wired to change color at different speeds?
The controller makes the light change. As the temps rise, the controller ads voltage to the fan motors. This makes the light change colors.
Old Jun 20, 2015 | 11:36 PM
quincyj34's Avatar
quincyj34
If I go the dcc route which model should I go with?
Old Jun 21, 2015 | 07:17 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Originally Posted by eakermeld
hey this looks familiar.iv got the same setup in my chip truck.
FK-75
L101 indicator
TADJ module
that's a couple hundred bucks you'll be happy you spent.these things are nice.
Old Jun 21, 2015 | 09:28 AM
eakermeld's Avatar
eakermeld
I went with the FK-95 controller. It was only 10 bucks more and has a larger heat sink. That way no matter what fans I use, I'll always have enough juice. The L101 indicator is super nice to have, it lets you know how things are working. And the TADJ module lets you adjust the temps on the fly. This is a super setup and I have to thank FORDF250HDXLT for introducing me to it.
Old Jun 26, 2015 | 03:29 PM
quincyj34's Avatar
quincyj34
I have been doing more research on the dcc controllers but hardly see anyone using them on the windstar fans. Will the fk-45 be sufficient or do I need the fk-75
Old Jun 26, 2015 | 06:47 PM
eakermeld's Avatar
eakermeld
The DCC controller will run almost any fan out there. Some may need the resistor installed to work correctly, which is like an extra $10 or something like that. It seems like on one of the pages I read, it mentioned Windstar fans, but I can't remember what it said about them. The 3 fans I am running pull about 42A wide open so I would say Windstar fans would pull less. The FK-45 would be sufficient to run them, but for just a few $s more you can upgrade to the FK-75 and you know you would have plenty of power. I went with the FK-95 because it was only a few $s more than the FK-75 and had a larger heat sink on it. DO go with the 10ga wiring he offers. His wiring is some kind of wire I have never seen before and looks to be super high quality, as are all the ends.
Old Jun 26, 2015 | 08:03 PM
eakermeld's Avatar
eakermeld
I found the info about the fans. It is in the troubleshooting section of the installation guide. It says that Ford Contour fans are the ones that have the "low impedance" type motor and need the resistor. Windstar motors are probably good to go.
http://www.dccontrol.com/FK75.pdf
5.4T
2004 - 2008 F150
Jan 31, 2017 10:15 AM
John - NNY
Dec 31, 2005 11:56 AM
