I ran across a rebuilt long block for sale that I am considering with an E4 block and D00E heads. Any concern with this combination? Anything I need to be looking for?
If you're going to go with a different block, look for a 94-97 F4TE roller 351. You'd be better off all around with a complete roller 351. Better cam & better heads (E7TE castings) Those D8OE heads are boat anchors.
Look for one either in a 94-97 pickup or van. They're pretty common in both applications around here. I snatched a good-un out of a 97 F250 a couple years ago for $325 (including the FZ 5 speed bolted to the back of it.)
If you're going to drive it a lot, then you'll need hardened seat installed in those. The chambers are 10 ccs smaller than the D8OE heads, so you'll get a boost in compression with those. Make sure they deck surfaces are checked and checked for cracks all over. Have the Thermactor bumps removed from the exhaust ports too
