Oil Problem
Old Jun 12, 2015 | 08:54 PM
sgrol's Avatar
sgrol
Oil Problem
I think my truck stopped using oil to lube the engine. Have 2,000 miles on current oil. Pulled the dipstick to check the level and the oil still looks as clean as the day I put it in. Not bad for an almost 100,000 mile engine.
Old Jun 12, 2015 | 09:25 PM
kper05's Avatar
kper05
No kidding. Mine is black as night by then. Are you all stock?
Old Jun 12, 2015 | 09:33 PM
System's Avatar
System
Prolocutor
Me too. Mines black a few days after a change in fact. Must be a limited edition 6.7.
Old Jun 12, 2015 | 09:35 PM
sgrol's Avatar
sgrol
No I'm deleted and I'm imagine that's why the oil looks so good. I checked it at 500 miles and it was clean. Figured it would be pretty dark by 2000 miles but was very surprised to see it so clean.
Old Jun 12, 2015 | 11:40 PM
kper05's Avatar
kper05
I assume removing the EGR reduces the rate of soot mixing with the oil.
Old Jun 13, 2015 | 07:17 AM
UGA33's Avatar
UGA33
Mine usually won't start turning black till about 4k miles into the oil change. That's when it will stop the "typewriter" tick. Who would have thought clean oil would be annoying....
Old Jun 13, 2015 | 06:45 PM
sgrol's Avatar
sgrol
I'll have to watch that. Mine never seems to lose the typewriter sounds.
Old Jun 14, 2015 | 05:43 AM
ruschejj's Avatar
ruschejj
I don't understand how soot can get into the oil/crankcase. Is it getting by the piston rings?
I always thought the oil turned black because the temps in the hot zones were so high. Like cooking the oil at the turbo or in,the heads? There's no oil in the actual egr unit is there? Does soot leak by the valve seals? I'm not experienced with engine tear down so I really don't know just how much blow by or leaking by the rings or seals there is. I guess ideally there wouldn't be any leaking of fuel or air by the rings so I figure there must be VERY little.
Old Jun 14, 2015 | 02:22 PM
kper05's Avatar
kper05
We're going to need someone more knowledgeable about this than I am but I'm going to type my thoughts anyways. I'm going off of what I've always heard which has also made sense to me that it's soot darkening the oil.
I don't know how the soot gets into the oil but it has to be from blowby. Two reasons I can think of why it's dark so fast is it's mixed with the existing dirty oil that doesn't drain and the fresh oil over a short time is collecting various soot particles from the engine.
In addition to that is the EGR. It doesn't have oil but it's forcing exhaust back into the cylinders. We know exhaust sent to the EGR contains soot because soot builds up in the EGR if the engine isn't worked hard often enough. Without EGR it makes sense the oil would remain cleaner longer because the engine is exhausting most of the soot the first time instead of ingesting it a second time.
It would be great if someone could explain this better or correct me entirely.
Old Jun 16, 2015 | 04:53 PM
sgrol's Avatar
sgrol
I agree with the EGR being a main contributor. UGA33 sees the same clean oil as I and we are both bypassing the EGR system. Other deleted components are in the exhaust pipe and wouldn't affect oil.
allcool
6.7L Power Stroke Diesel
Nov 19, 2015 07:11 PM
mvedepo
Nov 6, 2011 12:27 AM
puck1263
Dec 19, 2005 12:35 PM
cetane anyone ??
13
Feb 7, 2005 03:22 PM
Diesel Daddy
Jul 31, 2004 11:31 AM
