Help the old guy, me
Old Jun 12, 2015 | 04:14 PM
ct diesel's Avatar
ct diesel
I have a 2011 f250 extended cab 4x4. With 6.7 diesel. Have towing package and plow package.
I am looking to tow a fifth wheeler. Can I haul this camper?
Hitch: 1,996
Ship: 12,565
GVWR: 15,500
Cargo: 2,935
Old Jun 12, 2015 | 05:20 PM
senix's Avatar
senix
Barely.
Your hitch weight is gonna be about 3100 lbs. 20% of 15,500. That is more of a true #.
Put your truck on the scales and see what it currently sits at.
I would put your rear axle at about 3K right now. So as you can see your rear axle will be about 6100 lbs.
Your front is 6K so that is not an issue.
Your gonna need air bags.
I suggest a slightly lighter 5er. You can do it with your current truck though.
Old Jun 12, 2015 | 06:28 PM
System's Avatar
System
Prolocutor
Hitch: 1,996
Ship: 12,565
GVWR: 15,500
Cargo: 2,935
Remember, your 250 is 99% identical to a single rear wheel F350 with only 2 very small differences. So, your truck's ratings are actually de-rated from Ford to fill a different market segment. If you look at an identically equipped SRW 350 you will find your real payload based on it's 7k rear axle rating. I have a 2012 extended cab so pretty much the same truck as you but mine is rated at 11.5k GVWR. (So is yours off the books...) I routinely tow a 44.5' 5ver toyhauler weighing 17-19k and it tows FLAWLESSLY. I agree with Scott that you will need airbags as there are two very small differences between our trucks. The SRW 350 comes with a single upper overload spring and a taller spacer block under the rear suspension. Without these two things, your truck will sag quite a bit more than mine and the airbags will compensate for this 100%. Every other part on your truck is identical to a SRW 350 like mine so go for the trailer and a set of air bags and enjoy...
Old Jun 12, 2015 | 08:58 PM
Chad149's Avatar
Chad149
My thoughts echo Rodney's as well. My Fiver is just a tad bit heavier than what you listed, and I'm not truck shopping right now....lol.
I hit the scales last year for my memorial day weekend after filling water and gas tanks, plus lots of extras I don't bring for any other trips, and I was just a bit over GCWR. All my GAWRs were under limits.
Old Jun 12, 2015 | 09:03 PM
System's Avatar
System
Prolocutor
Yep, GAWR and tire ratings are the ones that count. Well, as long as it's not the phony de-rated 250 GAWR... I'm under mine as well but over my GCWR which is not a concern for me.
Old Jun 12, 2015 | 10:26 PM
wingedone's Avatar
wingedone
Hitch: 1,996
Ship: 12,565
GVWR: 15,500
Cargo: 2,935
I wouldn't.
Your trailer has a gvwr the same as mine. Mine has a pin weight of 3340 lbs.
Your cargo has to account for everything else you put in your truck (people, hitch, tools, firewood, pets, ladders, generators, etc).
So how much are you really putting in the truck, altogether? Do the math and you will get the idea.
I did and decided a DRW was the way to go for the weight I was carrying. Glad I did.
Old Jun 13, 2015 | 06:11 AM
System's Avatar
System
Prolocutor
I'm on two trailers in a row that have a higher GVWR than that and neither had a pin weight over 3k. The old calculation of pin weight based on GVWR is nonsense. We don't all run at the GVWR of the trailer. Floorplans, loading, tank location, and whether you travel with tanks full, all make a huge difference in pin weight. So, playing armchair scalemaster is about the most inaccurate thing people do on RV forums as there are just way too many variables. My current RV has a GVWR of 21k. My pin, loaded for travel with the garage empty (which makes the pin heavier), is 2900.
So, if someone is really interested in knowing where they stand, do a Cat Scale search near your dealer and check it out. If there isn't one, ask the dealer if they have a Sherline tongue weight scale. The heavier ones go to 5k so they can easily handle weighing the pin of most 5vers. Worst case scenario, buy one For $139 for piece of mind and sell it when the deal is done. Or, just buy the trailer, add some air bags, and enjoy. I'd go with the last option personally.
Old Jun 13, 2015 | 06:32 AM
senix's Avatar
senix
Cat scale is gonna be the only way to truly know what is going on.
Old Jun 13, 2015 | 06:33 AM
System's Avatar
System
Prolocutor
Old Jun 13, 2015 | 06:41 AM
senix's Avatar
senix
Originally Posted by Karl4Cat
but of course!
For the record here..this was my 2008 F250
Old Jun 13, 2015 | 06:44 AM
System's Avatar
System
Prolocutor
Here's mine with the garage and tanks empty.
Old Jun 13, 2015 | 07:23 AM
wingedone's Avatar
wingedone
Sigh,
I weighed the truck without trailer (still with hitch, generator, cover, and wife and I) and came in at 4500 lbs on the front axle and 4000 on the rear.
Then with the trailer:
Old Jun 13, 2015 | 07:28 AM
System's Avatar
System
Prolocutor
Yes, but your DRW is over 300 lbs heavier in the rear than a SRW. So, if you had a SRW, you'd still be under the 7k RAWR and 11.5k GVWR of the truck which the OP will likely be too...
Not criticizing your decision to buy a DRW. Just noting that you're rig would be under the ratings of a SRW.
Old Jun 13, 2015 | 08:39 AM
wingedone's Avatar
wingedone
Using your number of 300 lbs extra for my DRW over a SRW, my total weight would be 11580 with a SRW. I see no good reason to run over the GVWR of 11500 of a SRW truck when I bought the DRW for $500 over a SRW. Plus, as you already said, he is missing springs and thus capacity. So his capacity is not that of a 350.
Old Jun 13, 2015 | 08:47 AM
System's Avatar
System
Prolocutor
Actually, I said "OVER 300 lbs" which would put you, at the most, AT not OVER the GAWR or GVWR. More likely your DRW is OVER 500 lbs more with a longer bed, extra wheels and tires, bigger fuel tank, and all other associated parts. Plus, not everyone carries a genset in the bed. That's something you do and not something everyone needs to take into consideration. In fact, I have nothing in my bed but the hitch.
As to your $500 extra, you couldn't pay me $500 to take a DRW. 95% of it's life is not towing and you have a truck that is worse to drive 95% of the time. No thanks.
The good thing is they make chocolate and vanilla. Something for everyone. It's just hard to hear people constantly telling people they "need" more truck. While in fact, it may be nice to have when towing, it's not a necessity.
