Another inner fender question
Old Jun 11, 2015 | 08:55 PM
sp2015's Avatar
sp2015
I have a 65 f100 2 wheel drive. The inner fenders are shot as well as radiator support. My question is if I install the reproduced 4 wheel drive inner fenders and radiator support(64 earlier 4X2), is there a support that connect to the cab where the old channel did in the inner fender. If not is there a structural issue.
Old Jun 12, 2015 | 05:50 AM
jowilker's Avatar
jowilker
sp2015 Welcome to and the Slicks Forum.
I don't believe those parts will fit.
John
Old Jun 12, 2015 | 08:36 PM
sp2015's Avatar
sp2015
Thanks John. Would you be willing to explain why? I am sure you are correct I just need to understand myself.
Old Jun 12, 2015 | 08:45 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by sp2015
I have a 65 F100 2 wheel drive. The inner fenders are shot as well as radiator support.
My question is if I install the reproduced 4WD inner fenders and radiator support (64 earlier 4X2 ), is there a support that connect to the cab where the old channel did in the inner fender. If not is there a structural issue.
C2TZ-16138-G .. Radiator Support / Reproduced
1961/64 F100/250 2WD/4WD / 1961/66 F350/600 / 1965 F100/250 4WD / 1966 F250 4WD
C6TZ-16138-B .. Radiator Support / Reproduced
1966 F100/250 2WD
C6TZ-16138-C .. Radiator Support / Obsolete
1965 F100/250 2WD / 1966 F100 4WD
C5TZ-16054-B Right & C5TZ-16055-D Left .. Inner Fender Aprons / Obsolete
1965/66 F100/250 2WD / 1966 F100 4WD
1966 F100 4WD has coil spring front suspension, uses the same cab as 1965/66 F100/250 2WD. Uses the same Styleside beds as 1964/66 F100/250 2WD
Old Jun 13, 2015 | 11:40 PM
sp2015's Avatar
sp2015
Bill, Thanks for the part number but the ones I need are Obsolete as far as I can find. The spring style is not a issue here as the unit is setting in a 2002 4wd frame with torsion bar suspension that I have shortened. Did the inner fender connect to the frame on the 4wd for support? My concern here is supporting the area where the hood hinges mount to the cab.
Thanks
Old Jun 13, 2015 | 11:53 PM
NumberDummy
C5TZ-16054-B Right & C5TZ-16055-D = Obsolete > No Ford dealer or obsolete parts vendor has any.
Ask garbz2 (Dave) your question inre to the inner fender aprons. I don't have a clue, he does.
Dave was in CA today (attending the F100 Western Nationals truck show held @ Canyon RV Park in Yorba Linda, where "Tricky Dick" was born), probably won't be back in AZ till tomorrow.
btw: What a resident of IA may find interesting: Bumper sticker that the crew of the USS Iowa (BB:61), probably in the 1980's had made...has a turret with 3 16" guns pointing aft (towards you) with "Go ahead, make my day!" printed below the 16" guns.
There are a few of these bumper stickers available from the Battleship Iowa Museum, located here in LA LA Land (San Pedro Harbor).
Old Jun 14, 2015 | 04:14 AM
Crop Duster's Avatar
Crop Duster
Core Support
I've read, "by people who were selling them" that a 61-64 2 WD core support will work on a 1965 if you drill a couple of extra holes and remove a bracket. Don't know if that's true or not.
These folks probably have good used parts, not cheap though. Flashback F100's - USA Made Steel Made Repair Panels On This page will be only USA Made Repair Panels,, not like others that carry those Black Tawain cheap repair panels, Here is how I feel on ste
Old Jun 14, 2015 | 04:31 AM
Crop Duster
Sorry, Should have linked that to a different page on that site. Just go to the helpful hints page on that site. These guys saw up a lot of trucks so they know a lot about what will fit what.
jwitty
Apr 14, 2019 06:02 PM
glassmanbruce
Jun 25, 2017 07:52 PM
Lukas Riewe
Feb 26, 2016 03:16 PM
Customcab
May 16, 2009 01:53 PM
taylorjgreen
21
Sep 11, 2008 08:12 AM
