302 351 swap
Old 06-11-2015, 08:05 PM
JRS2's Avatar
JRS2
JRS2 is offline
302 351 swap
I could have done a search, but many of you guys know this in your sleep. I am planning on getting a 351 maybe this weekend but didn't think of one thing. The 351 had an automatic, my 302 has a manual. Flywheel - is this externally balanced for the engine ? Will the flywheel from the 302 fit the 351 ? If I do this, do I need to get it balanced for this engine ?
What other major issues might I run into during this swap ?
My host truck is a 92 vintage 4 wd and speed density.
Do have a set of GT40 p heads and plan to do a cam, long tubes and duals.
I know I have some reading and research, and will likely go with Conanski's cam suggestion.
Old 06-11-2015, 09:14 PM
Conanski's Avatar
Conanski
Conanski is offline
Received 1,024 Likes on 803 Posts
Yes.
Yes.. but it's the wrong balance so don't use it, you need a 28oz version. The 5.0 used a 50oz imbalance.
Old 06-12-2015, 08:09 AM
JRS2's Avatar
JRS2
JRS2 is offline
Ok so I need a 28oz version flywheel, just bolt it on, or does a balancing procedure need to happen with the actual engine I am using ?
Old 06-12-2015, 09:30 AM
Shadow944795's Avatar
Shadow944795
Shadow944795 is offline
28oz flywheel and bolt it on and you are good to go.
1986FordF150I300
41
05-17-2009 12:20 PM
reserectbronco
1978 - 1996 Big Bronco
02-11-2005 07:04 AM
hamcginn
02-01-2005 05:26 AM
Shovelhead 93
03-30-2004 05:58 PM
largecar
02-24-2003 04:04 PM
Quick Reply: 302 351 swap
