flywheel problem
Old Feb 23, 2003 | 07:18 PM
largecar's Avatar
largecar
Question flywheel problem
I just took out my week 302 out of my 87 bronco and put a fresh 351w in.But I have one problem I have A vibration at about 3000rpm.A budy of mine told me that I need to put A flyweel from A 351 and not A 302 is this true and if so do I need to get one for the year it.this is A standard trans.
Old Feb 23, 2003 | 11:36 PM
Quantrex's Avatar
Quantrex
flywheel problem
The post-81 302 flywheel won't work. You need a flywheel for the earlier 302 or a 351.
Old Feb 24, 2003 | 06:26 AM
1993F150XL's Avatar
1993F150XL
flywheel problem
Which flywheel are you running now? The 87 302 flywheel won't work on the 351. Quantrex is right, you need a 351 or early 302 flywheel.
Old Feb 24, 2003 | 04:04 PM
largecar's Avatar
largecar
flywheel problem
Well at least I can do this in my sleep after all I did it 3 times already.Ill try the 351w flywheel and see what happens.Thanks
