05 Navigator Battery Drain
Old Jun 9, 2015 | 08:10 PM
abes250's Avatar
abes250
I have a 2005 Navigator that cant keep a charge. I have started by hooking up a voltmeter to the system and started pulling fuses to see what is drawing the battery down while parked. I have not been able to pinpoint the problem. I heard that the diaode in the voltage regulator in the alternator could be compromised, so i installed anew one. Still have the problem. Any hints as to what might be going on will be greatly appreciated. When the battery is fully dead and I jump the vehicle, I get a "Check AvancTrac". Thanks for any suggestions in advance.
Old Jun 9, 2015 | 09:22 PM
alwaysfords41's Avatar
alwaysfords41
Rear wiper is common, pull that fuse.
Old Jun 10, 2015 | 08:28 AM
alloro's Avatar
alloro
Use your meter and tell us what the battery voltage is for each of these tests. First with the engine off, turn on the headlights for a minute, turn them off and take a reading, then with the engine running (headlights off) take a reading.
sandrew1202
25
Feb 16, 2018 12:51 PM
5280
Mar 14, 2016 08:36 AM
APEXDUCK
Dec 4, 2014 07:46 AM
slydog39
Electrical Systems/Wiring
Aug 2, 2013 04:21 AM
4BTF250
May 19, 2008 09:28 PM
