1965 F100 starting issues
Old Jun 9, 2015 | 09:44 AM
1965 F100 289's Avatar
1965 F100 289
Have a 1965 F100 with a non standard year 289, not sure what year, with a 3-speed manual transmission on the column. The truck no longer starts. We have replaced the starter and relay and still only get a single click when engaging the ignition switch. Tried to bypass the relay prior to replacing, still just one click. Through many owners and years, there are some wiring issues, but it did run and start just fine up until recently.
Thoughts on a fix?
Thanks
Old Jun 9, 2015 | 02:25 PM
MichiganLarry's Avatar
MichiganLarry
Sounds like the starter is bad. Make sure your positive and negative are in good shape and connections are clean. The ground side causes most starting issues. If this doesn't work I would pull the starter and take it to an autoparts store that can test it.
Old Jun 9, 2015 | 04:45 PM
62fordF250's Avatar
62fordF250
Check your battery cables and terminals. Cables can corrode due to a nick in the insulation or exposure to battery acid, which happens fairly often. One day there just won't be enough metal available to conduct enough amperage to start. Happened on my '62 not that long ago. Started up and then just wouldn't the next time. I took that opportunity to upgrade the positive and negative cables to a larger gauge. Starter turns every time now.
Old Jun 10, 2015 | 04:00 AM
Old_Crow's Avatar
Old_Crow
Since you already changed the starter, for the heck of it, loosen the belt and try and crank it. I've seen locked up alternators keep a motor from cranking.
For that matter, take a socket and breaker bar and try turning the motor with the bolt on the front of the motor. If the motor turns with the breaker bar, then I'd start checking wiring and grounds
Old Jun 10, 2015 | 11:46 AM
Tedster9's Avatar
Tedster9
Don't bother to check, replace all the cables and grind down to shiny bare metal the connection points at block, body, and frame.
Old Jun 11, 2015 | 02:04 AM
Jdeshler's Avatar
Jdeshler
That's interesting..
wyowagner
Sep 27, 2012 01:28 PM
deepbass
1978 - 1996 Big Bronco
Aug 19, 2008 10:55 AM
papertiger00
Jan 31, 2008 02:46 PM
ecktvch
Nov 30, 2003 04:53 PM
johnnyfulcrum
May 13, 2003 08:43 PM
