Sponsored by: Real Truck
Low battery and CEL
Old Jun 9, 2015 | 08:48 AM
Medic911's Avatar
Medic911
Low battery and CEL
2013 F250. Wife turned the ignition on to roll up the windows before the storm (good thing) , but left the switch on. Both batteries dead. I charged them both (although not completely). Started OK but have a check engine light on. Any worries???or should I just put the battieries back on charge?
Old Jun 9, 2015 | 12:38 PM
RV_Tech's Avatar
RV_Tech
When I did this with my 02 it took an eternity to bring the batteries back up to full charge. I would try that first. I found I had to charge them separately and then run it a good while. It did give me an unplanned opportunity to clean my cable ends and battery terminals.
Steve
Old Jun 9, 2015 | 12:56 PM
Medic911's Avatar
Medic911
Steve
In the process of charging now....and it is slow.
Thx for the reply.
Old Jun 9, 2015 | 07:05 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
If you can. Charge over several days on slow charge.
Old Jun 10, 2015 | 11:52 AM
droldsmorland's Avatar
droldsmorland
If you pull the batteries(or just connections) and charge them individually verses in parallel they will charge faster and it gives you the opportunity to clean the posts & terminal ends.
When charging in parallel you need a big fleet charger not a bitty dyi'er 6-10 amper.
Old Jun 10, 2015 | 12:56 PM
Medic911's Avatar
Medic911
I disconnected the second battery and charged them individually. Took a while. Appears all is good. CEL went out. thanks all for the advise.
plumm30
2009 - 2014 F150
44
Feb 12, 2016 01:54 PM
bakos
Jan 16, 2013 04:07 PM
FSJ-EARL
Jul 29, 2012 12:55 PM
paramednick
Electrical Systems/Wiring
Mar 8, 2010 06:08 PM
BlackLabel78
Feb 22, 2010 08:28 PM
