New 460 build What kinda power do think it will be making?
Old 06-07-2015, 06:08 PM
gus11208's Avatar
gus11208
gus11208 is offline
Hello fellas it has been a while since i been on the forums!! I'm in the middle of a 460 build for my 78 f150. I have a stock block bored .040" over with flat to hypoeutectic pistons only -.005 in the hole The rods are reconditioned the crank is stock. The cam is a comp cams 280h, The specs are 530 lift 230 @.050 lift duration 280 advertised duration 110 degree los with scorpion 1.73 ratio roller rockers. I bought a set or 60669 performer rpm heads 95cc chambers shaved to 92cc the heads are fully ported on the exaust side and port matched and bowl blended on intake side.The comp ratio is at 10.18 to 1 The intake is a port matched performer rpm air gap intake with a 750 hp series double pumper holly. Msd 6al box and blaster 2 coil with re worked dura spark dizy. Im running Full length fender well exit L&L headers and a duel 3" exaust .....
Thanks Jeremy
Old 06-07-2015, 06:21 PM
march's Avatar
march
march is offline
Sounds like fun! and expensive gas.
I'll put my nickle on 525 HP
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
At what RPM?
... or just before it kicks a rod through the block?
Old 06-07-2015, 07:01 PM
gus11208's Avatar
gus11208
gus11208 is offline
I doubt that it will see over 5800 rpm
Old 06-07-2015, 07:24 PM
Jrgunn5150's Avatar
Jrgunn5150
Jrgunn5150 is offline
Eh, its healthy for sure, should be about four fiddy
Old 06-08-2015, 01:36 PM
somethingclever's Avatar
somethingclever
somethingclever is offline
with that cam - 475hp/525ft-lbs
With cam sized for the heads and intake - 75 more hp
It will be pretty lazy down low IMO....an ok truck pulling engine....not so great on the street.
Old 06-08-2015, 07:35 PM
gus11208's Avatar
gus11208
gus11208 is offline
I was running this cam in this engine for a year so far so good!! I'm nor sure if I would want to go more radical I a heavy truck. The performer cam I would think make it more lazy down low. But I'm not sure what are your thoughts??
Old 06-08-2015, 10:33 PM
somethingclever
I would look for something like an extreme energy or 4x4 cam. Those magnum grinds are pretty old school.
I have a 460 in my mustang with slightly cleaned up iron heads, performer rpm intake, mid length headers, 10.5:1, that same 280h and made 355/400 on a dynojet through a c6. I figured 425hp/475tq at the crank. Made good torque everywhere...but you will have a lot more port volume to fill with your head/intake selection. Neither one is what I would pick for a truck engine that is used on the street primarily.
By the way I think I have talked to you at mineral beach a few yrs back.
Old 06-09-2015, 05:04 AM
gus11208's Avatar
gus11208
gus11208 is offline
Yep that would be me lol.
Old 06-10-2015, 10:52 PM
gus11208's Avatar
gus11208
gus11208 is offline
Finally got one of the heads on the other side one will be soon to follow
Bowl blend with port matching!
Old 06-11-2015, 06:53 AM
somethingclever
Are you going to dyno it so we know how much power it made? Who cleaned up the heads?
Old 06-11-2015, 10:15 PM
gus11208's Avatar
gus11208
gus11208 is offline
If i dyno it it will probably be in the truck. Maybe I'll put it on a chassis dyno up at carlisle all truck nats. Kevin down at kmp performance and machine did everything. He's down in west newton.
Old 06-12-2015, 07:17 AM
somethingclever
I have not used them before but have heard good things.
Good luck with your build....I will be at truck nats this year.
There are a few dyno's in the area...mustang and dynojet...I have used both.
Rodeheavers in McClellandtown - mustang dyno and an old-school Ford BBF guy
Wolfpack Speed in Robinson/Carnegie area as well - dynojet
Old 06-13-2015, 10:52 AM
gus11208's Avatar
gus11208
gus11208 is offline
Thanks for the info. Maybe I will see you at carlisle! The trucks in the invitational display in building T I will probably have a tent set up some where else though!
Old 07-05-2015, 09:38 PM
gus11208's Avatar
gus11208
gus11208 is offline
Finally got the rest of the moter together here are some pics.
Quick Reply: New 460 build What kinda power do think it will be making?
