Skip under load
Old Jul 29, 2003 | 12:43 PM
1/2of3's Avatar
1/2of3
Unhappy Skip under load
Bought 99' explorer xlt new. Now has 100000 mi. Recently with A/C running and going up inclines where the engine does not have to shift to a lower gear, it skips and cuts back until I turn off the A/C or level of and reduce the load. Hot weather may aor may not be the problem. Please advise....
Old Jul 29, 2003 | 01:43 PM
Jethrohoyt's Avatar
Jethrohoyt
Skip under load
All I know is what I learn from my Ford trucks.
My 98 XLT Exploder (110,000 miles) just had a similar problem. I have the Auto 4x4 option and I noticed that under load, starting on a hill, in bottom gear loaded with a trailer, it would skip and judder. I finally tried turning on 4x4 manually in the same circumstances. It no longer skipped when in 4x4.
I concluded that it was the transfer case. My tranny shop confirmed it may be as they had seen many of them changed out ($1400 each!).
My delaership suggested changing the TC oil as a first step (hell; I'll do anything to save $1400). So far, 2 weeks into it, its worked. New oil in the transfer case has cured the problem.
How this relates to the a/c being on, I cannot say. Maybe coincidence or maybe my post is no use. Try turning on 4x4 when it does it, see what happens..........
Jethro
Old Jul 30, 2003 | 02:45 PM
1/2of3's Avatar
1/2of3
Skip under load
I'll give it a shot. Thanks for the advice!!
