help?
Old Jun 6, 2015 | 01:45 PM
helpolfaithful's Avatar
helpolfaithful
help?
I've got a 86 f150 inline 6 4spd. Sat for years without a touch till I saved her. I'm having trouble getting the engine to give a good turn. Anyone got a suggestion on why?
Old Jun 6, 2015 | 02:27 PM
Harte3's Avatar
Harte3
"Sat for years without a touch..." That's why.
Try: Pull the plugs, pour a bit of MMO or some other cylinder top oil in the cylinders, let it sit for a bit and then use a breaker bar/socket on the crank nut and start working it back and forth until it moves freely.
Old Jun 8, 2015 | 09:32 AM
The Frenchtown Flyer's Avatar
Make sure the clutch disc has not rusted on the pressure plate/flywheel. Some discs - especially those containing sintered iron - will do that.
Old Jun 8, 2015 | 11:04 AM
seattle smitty's Avatar
seattle smitty
You should pull the fuel tank and get it boiled out or steam-cleaned, but at least replace all fuel filters and all the rubber fuel lines (gasohol degrades them), and blow out the hard lines. Then when you put fresh fuel in the tank, first mix in some 2-stroke oil, which will help give the poor engine a chance.
Old Jun 10, 2015 | 10:13 AM
ZarK-eh's Avatar
ZarK-eh
Itsa Jeep thang, I know... but he does deal with a rusty crusty engine that might help here...
Dirt Everyday : Driveway Rescue of a 1950 Jeep CJ-3A! - Dirt Every Day Ep. 33
Edwardthc
Nov 30, 2018 10:26 AM
thedieselkid
17
Mar 1, 2012 12:20 AM
nlareau
Aug 1, 2011 02:01 PM
IowaTower
Apr 22, 2007 02:30 PM
Gear Up
Mar 16, 2006 09:33 PM
