Jag ifs jitters
Old Jun 5, 2015 | 07:23 PM
Noob52's Avatar
Noob52
Jag ifs jitters
So I think I am almost ready to install my jag ifs. Any last words of wisdom from the guys on here? I think I have read every post twice, but want to make sure! I am welding to the frame. Motor is out and the frame where the jag will mount is level front to back and side to side. I have centered the ifs in the wheel well and the ifs is level also. Am I missing anything?
Old Jun 5, 2015 | 08:00 PM
seaves46's Avatar
seaves46
Make sure your frame is at your ride height or preferred rake .
The bottom of the jag cross member must be level front to back and side to side .
If you weld it in with EVERYTHING level and later on when your truck is completed the rear is higher than the front it will mess up the f/e geometry .
It may not be a lot , but it may be harder to get a correct wheel alignment .
Old Jun 6, 2015 | 06:45 AM
drptop70ss's Avatar
drptop70ss
Lots of pics in both of my build threads. Both of mine are welded up level front to back with the frame level front to back. I may be running some rake but I am not worried about the alignment, it will be fine. I lived through the 1980s, hijacker air shocks and all
armyaviation
Nov 20, 2021 07:09 AM
keisha9
Aug 15, 2013 02:58 PM
Holehawgg
Jul 5, 2012 06:24 PM
F100man
Oct 20, 2007 12:45 AM
Gary E
Dec 14, 2006 01:43 PM
