1977 F660 4WD Axle Swap
Ive got a 1977 F660, 4WD truck that was used as a brush fire rig. It's got 8600 original miles and is a great truck. However, it has granny gears and I'd like to modernize the axle ratios to something more driveable for use in my business. Rear axle is a Rockwell 8200-R-1188 D, Ford Axle code is 64J. Can I swap the differential or do I need new axles, etc? Where do I start?
Ive got a 1977 F660 4WD truck that was used as a brush fire rig. It's got 8600 original miles and is a great truck.
Rear axle is a Rockwell 8200-R-1188 D / AXLE code stamped on the Warranty Plate: 64J
There is no such thing as an F660, it's an F600. 1st 3 digits of the VIN: F66 = F600 4WD (gas).
MODEL aka TYPE/GVW code stamped on the Warranty Plate:
F660 = F600 4WD (gas), 21,700 lbs. Gross Vehicle Weight Rating.
F661 = F600 4WD (gas), 24,000 lbs. Gross Vehicle Weight Rating.
64J: 64 = Rockwell-Timken model F-106 Rear Axle / 6.80-1 / 15,000 lbs. Rear Axle Capacity // J = 5,000 lbs. Capacity Ford Front Axle with Power Steering.
I have detroit lockers in both of mine.. rear was easy peasey... about 500... front was very hard to find and cost me over 1500... I think I have 5 k wrapped up in just the axles/tires now
I have the same axles in my firetruck... I also found the mud racers in the midwest had parts for them... as these axles were popular with them... google work is your best friend
