Sponsored by: Real Truck
350 SRW and DRW differences
Old Jun 4, 2015 | 10:17 PM
bobv60's Avatar
bobv60
for 2005, what are the differences between the SRW and DRW f350s/
Old Jun 4, 2015 | 10:21 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Roughly speaking, the rear axle and rear springs are the main difference, assuming powertrain options are identical. DRW came standard with a rear sway bar, it was an option on SRW.
Front axle spacers to accommodate the deep offset of dually wheels, bolt pattern of wheels. Front spring rate is set based on engine and options. With diesel 4.10s were standard and 4.30s were optional on DRW, SRW was always 3.73. IIRC gassers had 4.10 and 4.30 options for both SRW and DRW, maybe depending if it was a 5.4 or 6.8. Manual vs automatic changes ratings regardless of SRW or DRW.
All the details:
https://www.fleet.ford.com/truckbbas...essd-exlbb.pdf
Old Jun 4, 2015 | 11:08 PM
bobv60's Avatar
bobv60
That would explain the high RPMs at 60mph. Must have the 4.30 gears. Sense this will only be towing HEAVY about 10% that might be a deal killer.
Old Jun 4, 2015 | 11:09 PM
bobv60's Avatar
bobv60
What rear axle does the DRW have?
Old Jun 5, 2015 | 05:21 AM
senix's Avatar
senix
On the door label, what is the axle code? Axle code is probably in the tech folder.
Old Jun 5, 2015 | 09:13 AM
texastech_diesel
Token Redneck
If you're towing anything, you'd want the 4.30s instead of 4.10s in a DRW. Deeper gears are better. I wish my SRW 6.0 had 4.10s stock. MPG difference is negligible.
Old Jun 5, 2015 | 09:24 AM
Thenewboss's Avatar
Thenewboss
Dana 80 I believe, while the SRW has the Sterling 10.25. If I'm wrong someone please correct me.
Old Jun 5, 2015 | 02:15 PM
bobv60's Avatar
bobv60
I don't know for sure I did read in about 2002 when ford when to the Dana 60 front they went to the 10.5" rear axle
Old Jun 5, 2015 | 05:07 PM
Thenewboss's Avatar
Thenewboss
Let me clarify...Dana 80 in the rear for the DRW, 10.xx in the rear for the SRW. Dana super 60 (Super 60 has the offset diff?) in the front for as long as I can remember.
Old Jun 6, 2015 | 08:33 AM
speakerfritz's Avatar
speakerfritz
in 05 the DRW went to 8X200 lug spacing on all hubs.
prior to 05, lug spacing was 8X170
05 and later SRW have 8X170 lug spacing
ditto on the leaf, axle, anti-sway, front hub spacer diffeences.
the main differences is the perfomance....drop a 5000lb pallet of cememnt bags on a DRW and is drive and go.
on my SRW, wehn I dropped a 5000lb pallet of cement bags.....even with over load leafs, boom....the rear end bottomed out.
no sag on large trailer loads either.
performance...thats the main difference
Old Jun 6, 2015 | 11:16 AM
senix's Avatar
senix
Mine has a 9650 lb rating for the rear axle. A srw f350 is gonna be about 7k depending on year
Old Jun 6, 2015 | 11:38 AM
Super Duty DJ's Avatar
Super Duty DJ
The number of tires you have to buy of course.
Sorry, I had to.
petei
Jul 26, 2016 08:04 PM
rcs101
Nov 26, 2013 07:10 PM
tjc transport
Jun 19, 2013 05:51 PM
RA31925
19
Jul 23, 2012 06:15 AM
jbawilliams
All Things Towing
Aug 19, 2006 12:13 PM
