Sponsored by: Real Truck
Gem and transmission range sensor
Old Jun 4, 2015 | 02:29 PM
kb3mtv's Avatar
kb3mtv
Has anyone ever lost a gem due to a faulty range sensor? Ive narrowed down my repetitive frying of my gem and the range sensor is my only logical conclusion. Before I start tearing into the truck I wanted to see if anyone has had this problem before.
Thanks!
Chris
99 f250SD 5.4l automatic
oh and the gem burns up the ground pin and circuit on the board itself. I have verified the ground multiple times and it is fine.
Old Jun 4, 2015 | 06:39 PM
Tom's Avatar
Tom
Hi Chris,
I've never heard of this before, but frying a GEM isn't a common thing. Have you identified the circuit that is burned as the one for the TRS?
Old Jun 4, 2015 | 08:03 PM
kb3mtv's Avatar
kb3mtv
Not exactly. I did some digging through the diagram and found that If i apply a ground through the acc delay ground on the fusebox I can get the fried module to work again temporarily. I used my voltmeter to complete the circuit and measured the draw while using different functions and found the wipers, 4wd, dome light, buzzers, and so on and all seemed well, (.5 amps at max). So I got frustrated and pulled over. Soon as I put it in park, before I could even react. Saw the meter skyrocket and than dead.
According to the diagram the neutral position indication is the only communication between the GEM and range sensor so im assuming thats where its from
I do have a code for the range sensor. P0705.... no communication, but I have no issues starting the truck, reverse lights function, etc...
Thank you!!!
Chris
Old Jun 4, 2015 | 09:07 PM
projectSHO89's Avatar
projectSHO89
What is the connector number and pin#(s) that are being burned?
Old Jun 5, 2015 | 09:10 AM
kb3mtv's Avatar
kb3mtv
On the connecter with 26 pins, its #26 and its the ground for the gem itself. Just to clarify, the pin itself isn't burned but the gem circuit board is.
Thank you!
Chris
Old Jun 9, 2015 | 09:07 AM
kb3mtv's Avatar
kb3mtv
Bump and does anyone have any ideas?
Thanks,
Chris
Old Jun 9, 2015 | 09:59 AM
projectSHO89
I'd be inclined to install a fuse across the circuit trace that is getting burned, then check to see if it's getting fried when the gear selector hits neutral. If so, I'd likely conclude that there's an internal short in the DTR switch that's inadvertently applying battery power to the neutral sense circuit. ... or just replace the DTR switch and see if that fixes the problem. I'd still install the fuse since that's cheaper than replacing GEM modules for testing.
RogerGym
1983 - 2012 Ranger & B-Series
13
Aug 27, 2020 03:51 PM
Mi04f150
2004 - 2008 F150
Jun 28, 2016 10:27 AM
charles5000
Jan 28, 2014 07:31 AM
joegebff
17
May 2, 2013 05:50 AM
D Ray
Aug 10, 2010 09:41 PM
