Oilfilter for 7.3
Old Jun 3, 2015 | 04:28 AM
Webasto 9.1KW's Avatar
Webasto 9.1KW
Oilfilter for 7.3
As I live in Sweden there is not many of the shell filters for the 7.3 Powerstroke...
There is, for some reason for GM and Cummins. I wonder if any other engine uses the same filter att the 7.3 as most engines have som sort of "standard" filter used by others.
You know which other engines use the same filter so I can look for those insted?
/Tnx.
Old Jun 3, 2015 | 04:35 AM
David7.3's Avatar
David7.3
I dont know of any, The 7.3 has it's own filter, the 6.0, 6.4 and 6.7 dont even fit it. you dont have purolator there? L44872? good luck If you have GM these will cross A/C delco PF2174, GM 25177933, Shell SH39
Old Jun 3, 2015 | 04:56 AM
Webasto 9.1KW
Thanks. That part number helped alot! Just seems strange that they would make one single filter just for the 7.3...
Old Jun 3, 2015 | 12:49 PM
Buck Dharma Fan's Avatar
Buck Dharma Fan
Motorcraft Filter. 1995
Old Jun 3, 2015 | 01:54 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Years ago, I can remember that Fords and Mopars could use the same filter. PH8A was a Fram number. And if space was tight, PH43 would fit the same base. These could be used on many of the Fords and Mopars. Not today. I don't know of a single motor that uses the same oil filter as the 7.3psd.
Old Jun 3, 2015 | 04:36 PM
fordpride's Avatar
fordpride
If you have a big truck dealer/parts house by you give part# FL1995 and the can cross it over for you
Old Jun 3, 2015 | 04:39 PM
fordpride's Avatar
fordpride
Oil:
Motorcraft FL-1995 (Ford part # F4TZ-6731-A)
Fleetguard LF-3630 (standard media)
Fleetguard LF-3974 (Stratapore)
Fleetguard LF-3374 (Stratapore--extended capacity)
Wix 51734
NAPA 1734
Baldwin B7039
AFE Proguard D2 44-LF004
K&N HP6001
Purolator Pure One PL44872
Purolator L44872
Fram ExtraGuard PH3786
Fram ToughGuard TG3786
Fram Wearever HD HPH3786FP
Carquest 85734
AC-Delco PF2174
Amsoil ASF99
Amsoil SDF99
Donaldson P550371
Donaldson EFL7405
John Deere TY24772
Old Jun 4, 2015 | 07:17 AM
CampSpringsJohn
If John Deere makes that filter, then perhaps they have an application that uses it too. Or, they just wanted to capitalize on all the farmers that own 7.3's!
Old Jun 4, 2015 | 08:22 AM
Buck Dharma Fan
Wow PH8A, brings back memories of my '90 Bronco w/ 5.8. Loved that truck too.
Old Jun 4, 2015 | 08:31 AM
CampSpringsJohn
Me too. I owned several mopars through the years. And Dad owned Ford trucks.
dyoungen
18
Dec 21, 2010 06:53 PM
njstevens
Feb 18, 2010 02:32 PM
ajeffrey
Apr 14, 2006 11:56 AM
Metro-Nut
Nov 10, 2004 01:53 PM
kitsapcountychopper
Mar 8, 2004 06:40 AM
