DPC-203 All the same?
Old Jun 2, 2015 | 12:15 PM
whybnormal's Avatar
whybnormal
So after spending hours diagnosing this truck I'm pretty certain that the PCM is wasted. It came in with a no start which I posted about a few days ago and after testing all the usual I found oil/diesel soaked and bare wires under filter housing that go to the IPR and I think they shorted and burned up the driver for IPR in the PCM. I replaced them and still got a no start unless I jump the IPR to battery. I ohmed wires to PCM and it all checked out good so I tried my PCM in another 95 truck and got the same no start with low ICP pressure cranking (WTS lamp did come on). I found a DPC-203 at Rockauto with same part# as mine (F5TF-12A650-FJ) but the description says for automatic. Mine is standard and after emailing them they told me it was not compatible. I have read that I can use any PCM of the same DPC-203 family but I have seen mixed results and posts as to the differences.
Old Jun 2, 2015 | 01:23 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
The auto pcm should would but it might not run right. I've heard that because the pcm is searching for the auto trans the idle can wander.
Old Jun 2, 2015 | 01:28 PM
cowmilker08's Avatar
cowmilker08
I've also read that fueling schedule is slightly different.
Old Jun 2, 2015 | 01:47 PM
FI460's Avatar
FI460
Quite a few of us running auto pcm's after we've swapped manuals in. I have no noticeable issues with mine. Some guys get wandering idles or romps on start up.
It's been right at 2 years since I put the manual in my truck and no issues so far. You may have to make some wiring modifications for the cruise control to work.
Old Jun 2, 2015 | 06:06 PM
whybnormal's Avatar
whybnormal
I appreciate the responses. I may send it off for repair if I can't find a manual one. I wouldn't mind the minor differences but it's for a customer. I'll post back with the results.
Old Jun 8, 2015 | 09:54 AM
whybnormal's Avatar
whybnormal
Update: Swapped in used a PCM I found at the wrecking yard and truck started and is running just fine.
whybnormal
Jun 8, 2015 11:56 AM
Jimbo302
Jul 20, 2013 04:38 PM
redman84
Mar 12, 2011 07:47 AM
F-1CLEVELAND
23
Mar 5, 2009 08:40 AM
RoyLayman
1997 - 2003 F150
Aug 26, 2004 11:04 PM
