Sponsored by: Real Truck
Ford Gold Coolant Question
Old Jun 2, 2015 | 08:27 AM
tangster's Avatar
tangster
Sorry for using up space about 5 mins after posting I found the answer here in the 1999 too 2002 section doing another net search. There its a different Bittering agent in it was what That post mentioned
I'm at 53K miles on my 05 F250 figured its due for a cooling system flush and I'll be installing a coolant filter set up as well.
Here is my question my owners manual says too use Motor-craft/Fords
Genuine Ford Fluid VC-7-A Gold Concentrated Antifreeze/Coolant .But just looking on line for it all I can locate is the Ford Fluid VC-7-B Gold Concentrated Antifreeze/Coolant and the info says to use B in Ca. and Or only but if there is no chemical or formulation difference I'd assume the VC-7-B will work as well and the VC 7 A does ? As I'm not in Ca. or Or. I doubt the coolant will know either
So I figured I'd ask here before I screw up.. Questions save time and money and I looked all over and could not find this question being asked before Thanks for any info Guys ..
Old Jun 2, 2015 | 11:55 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
ZEREX GO5 is the same as Ford Gold.
Instead of going back to Ford Gold, have you given any thought of going to the CAT EC-1?
A lot of 6.0 owners have. To eliminate the silicates found in the Ford Gold, that plugs the oil cooler over time.
Do a little search on CAT EC-1 and see what you think.
https://www.ford-trucks.com/forums/9...nge-101-a.html
Old Jun 2, 2015 | 12:52 PM
tangster's Avatar
tangster
I will change it over next time I just received the darn Ford Gold I only got 3 Gals as that is what someone told me was the amount I needed but I see some say 3.5 to 4 Gals. for a complete flush ? So I was jut going to get that Zerex GO5 Locally like 16.00 a Gal and add that if more coolant is needed..
I'm installing a coolant filtration system with the EGR cooler delete and want to make sure its all clean and fresh.. But next time I'll change coolants Thank for the info..
Old Jun 2, 2015 | 02:17 PM
amdriven2liv
Have fun!
And if you ever need to get info again, swing on by the 6.0L forum. Lot's of helpful people there!
Old Jun 2, 2015 | 02:55 PM
tangster's Avatar
tangster
Have fun LOL thanks but I have other plans (: Thanks for the info on that tip on the 6.0 forum
Kongerup
Feb 2, 2015 11:26 AM
Subzero68
Dec 18, 2013 08:30 PM
ndlawrence
General Diesel Discussion
Jun 5, 2013 08:57 PM
polaris_5256
Mar 24, 2013 10:46 AM
PADLER
Dec 16, 2010 08:50 PM
