seafoam + 6.0 = bad problems
Old Jun 1, 2015 | 11:16 AM
tankd72's Avatar
tankd72
So I have been having the injector stiction problem when cold. I spoke to a diesel mechanic, he said try seafoam in it to clear up the problem. So I bought a bottle put half in the tank and half in the oil. So after I started and let idle for 5 min it acted like it ran out of fuel. So let it set for a minute and hit the key fires right up. Idle 2 min and dies again. Pulled fuel filters and they look to be clogged up. Changed them started up idled for 10 min sounded fine until you hit the accelerator pedal a few times is dies again. Ok so now this just sucks back to check filters and they are clogged again. So now I am waiting to try and borrow a pump to get the 15 gal of fuel out of the tank get new filters again put new fuel in it and pray that cures it.
Is there any way to use the pump on the truck to drain the tank?
Old Jun 1, 2015 | 11:54 AM
WatsonR's Avatar
WatsonR
Disonnect the fuel line near the upper filter, that should get you about 15-20 seconds of run time. You could break it anywhere after the pump to make catching the sludge easier. Just key it a bunch of times and keep the batteries charged. Remove the FICM relay as well.
Archoil 9100 next time and synthetic oil.
Old Jun 1, 2015 | 11:56 AM
Rusty Axlerod's Avatar
Rusty Axlerod
What's clogging the filters? Can you describe what they look like.
Old Jun 1, 2015 | 12:37 PM
tankd72's Avatar
tankd72
I tried siphoning the tank but there must be a screen or something in the way cant get the hose all the way down into the tank.
Old Jun 1, 2015 | 04:06 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
You could probably disconnect the fuel line to engine on the HFCM inside the driver's side frame rail directly under the driver's door. Cycle the key on to KOEO, the pump will run for about 20 seconds before it kicks off. No idea of the flow rate or how long it would take.
Old Jun 1, 2015 | 05:33 PM
evan1242's Avatar
evan1242
that is weird.. i put seafoam in my tank when i first got my 6.0 about 8 months ago.
no issues with it whatsoever..
Old Jun 1, 2015 | 05:49 PM
WatsonR's Avatar
WatsonR
May have something else in the tank besides diesel fuel. Maybe a delaminating tank, water or algae.
Old Jun 1, 2015 | 06:07 PM
tankd72's Avatar
tankd72
After talking to others the seafoam is basically cleaning all old crap out of the tank. I am going to disconnect the fuel line from the HFCM attach a 3/8"line cycle the key to pump out all the seafoam'd fuel. I wont pull the filter out of the HFCM so it protects the actual pump from whatever crap comes out.
Old Jun 1, 2015 | 11:18 PM
diesel_dan's Avatar
diesel_dan
I like it. You have a stiction problem only on cold start and now Seafoam is cleaning all the "junk" out of your tank?
It didn't clean your injectors while it was busy doing that by chance, did it?
I think the junk in your tank is Seafoam... I'll just go off the anecdotal evidence you provided of a couple sets of clogged filters after putting it in...
It probably works in the cooling system to clean out clogged up oil coolers just as well...
Old Jun 2, 2015 | 08:47 AM
tankd72's Avatar
tankd72
Seafoam will now only be used in the lawn mower and weed eater.
Old Jun 2, 2015 | 09:44 AM
tankd72's Avatar
tankd72
Bye the way the seafoam'd fuel pumped out looked like Budweiser ..lol
Old Jun 2, 2015 | 10:21 AM
diesel_dan's Avatar
diesel_dan
HaHaHa Now if it could turn diesel into beer, we might have something there!
Good luck, I'm sure you'll get it cleared up...
Old Jun 2, 2015 | 10:25 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
That's the ONLY place that stuff belongs....
I don't even let it near my mower. I use Berryman's B12, works much better than seafom.
So now you know, 6.0 + Seafoam =
You may also consider changing your oil too since Seafoam likes the taste of orings and seals. Ask me how I know....
Old Jun 2, 2015 | 10:42 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
I too used SeaFoam to fix an injector issue..... worked well for me! 1/2 into the the top of the fuel filter and 1 1/2 cans into the oil. Drove for 100 miles and changed oil. Done!
Old Jun 2, 2015 | 11:18 AM
Misky6.0's Avatar
Misky6.0
I successfully used seafoam in my lawn mower a couple weeks ago - it cleaned up the rough running/surging issue fairly quickly, it didn't help my standby generator though (new carb gasket kit on order for that)..
I also use the StarTron Enzyme Fuel Treatment now in my small engine fuel canisters.
