Hard starting
Old May 30, 2015 | 08:42 AM
nycstev's Avatar
nycstev
Hard starting
2001 e250 with 4.2. when I go to start it first thing it doesn't crank right up. Have to hit it again and then it stumbles few a few seconds then fires. When it's hot it's fine. Any ideas? Thanks
Old May 31, 2015 | 07:09 PM
Wildman25's Avatar
Wildman25
Sounds like a fuel pump/pressure problem.
When you first turn the key to "ON" you should hear the fuel pump "whirl"
Do a fuel pressure test on the fuel rail schrader valve, see if it's with in spect's.
Next time you cold start it, turn the key to "ON" for a few (5) seconds, then turn it to start, if it fires right up, then you have found the problem, fuel pressure is not building up for the start. Could also be a bad fuel pressure regulator, leaking down over time and not keeping pressure in the system.
Old May 31, 2015 | 10:54 PM
98Econoline150's Avatar
98Econoline150
I am not familiar with the 4.2 Essex but if it is equipped with a MAF sensor it may be bad enough to effect cold starts but not bad enough to throw a code.
Old Jun 1, 2015 | 07:02 AM
nycstev's Avatar
nycstev
Thanks for your help!
jw1028
3.8 & 4.2L V6
Feb 14, 2020 07:58 PM
Banjo250
1997 - 2003 F150
18
Jul 2, 2019 04:29 PM
kwade66
Jun 3, 2006 04:06 AM
JL_Aero
Aerostar
Nov 5, 2004 07:44 AM
bdonalds
Apr 4, 2001 02:16 PM
