Aerostar Ford Aerostar
Hard Starting
Old Nov 3, 2004 | 09:21 PM
JL_Aero's Avatar
JL_Aero
Cool Hard Starting
90 Aerostar 4.0l. Strange starting problem. It takes exactly 4 serious cranks to start the car. On the 4th crank, it starts great and runs well. This is true even if you start up a few minutes after stopping and the motor is warmed up. I can hear the fuel pump engage each turn of the key.
An interesting things is, if I turn the key to full on, without cranking, and leave it a couple of seconds, then repeat a total of 4 times, if I then crank the engine it starts right up.
I have changed virtually everthing due to other problems, including the fuel pressure regulator, but still the problem. It's almost like it takes a while to build up the pressure. Filter is good, new gas cap, etc.
Any thoughts,
Thanks,
John
Old Nov 4, 2004 | 07:56 AM
M.Herrington's Avatar
M.Herrington
I have the same exact problem here, I've done all of the above, and my fuel pressure tested ok as well.
Old Nov 4, 2004 | 09:17 AM
Racerguy's Avatar
Racerguy
It sounds like maybe your fuel pump is getting weak and taking a while to build pressure. Eventually it will probably die altogether.
Old Nov 5, 2004 | 06:54 AM
JL_Aero's Avatar
JL_Aero
Thanks,
I have given it some thought. How hard is it to change?
John
Old Nov 5, 2004 | 07:44 AM
M.Herrington
it's a royal pita, the pump is on the top of the tank, if it fixes your problem, let me know, and i'll unhappily replace mine.
