1978 - 1996 Big Bronco
Why do I have two vacuum canisters?
Old Jul 28, 2003 | 11:59 PM
bigric's Avatar
bigric
The one on the passenger side is plumbed up, but there's also one behind the driver side headlight. The vacuum source line is hooked up, but the output port is plugged. The second can isn't even on the vacuum diagram. When I pull the source line off of the can, the can sucks in a lot of air, so I know it's holding a vacuum, but for what?
Old Jul 29, 2003 | 01:47 AM
kd5kuu's Avatar
kd5kuu
My '95 doesn't have one behind the driver's headlight, but it does have two. The coffee can one is for the EGR and AIR systems, and another one is hidden under a sight shield and is for the A/C controls.
Old Jul 29, 2003 | 09:35 AM
bigric's Avatar
bigric
Do both of your canisters have things attached to both the source and output ports? My extra can has nothing attached to the output port.
Old Jul 29, 2003 | 02:08 PM
kd5kuu's Avatar
kd5kuu
My coffee can looking one has lines attached to both inlet and outlet. This is necessary because there is a check valve in the canister so as not to release vacuum back to the manifold when manifold pressure drops below what's in the can. My A/C vacuum reservoir has only one line going to it with a check valve upstream of the reservoir that is incorporated into a "T".
Old Jul 30, 2003 | 07:25 AM
fcarruth's Avatar
fcarruth
Would you happen to know where the a/c vacuum resevoir is on an 89 ? Where is it on your's ?
Old Jul 30, 2003 | 11:54 AM
kd5kuu's Avatar
kd5kuu
My A/C vacuum reservoir is located behind a sight shield located just behind the accumulator (that shiny black cylinder). You can locate it on my '95 by following a short vacuum line coming off 90* from the check valve located in space between the accumulator and the upper manifold.
Another description is behind the foil heat reflector on the passenger side of the engine compartment on the firewall.
Old Jul 30, 2003 | 11:55 AM
kd5kuu's Avatar
kd5kuu
I don't know if this is where it will be on your '89 though. Just know that after the check valve there will need to be a vacuum reservoir somewhere in order to operate the A/C controls when accelerating.
Old Jul 30, 2003 | 12:31 PM
fcarruth's Avatar
fcarruth
Does it have a vacuum line coming into it and a lever that go through the firewall ? If so, I think I know.
Thanks for your help,
Old Jul 30, 2003 | 12:46 PM
JBronco's Avatar
JBronco
On my 90, there is a vacuum canister behind the driver's side headlight, and another on near the passenger side fender well, not hidden by any sight shield.
Old Jul 30, 2003 | 12:47 PM
JBronco's Avatar
JBronco
PS - they are both coffee cans.
Old Jul 30, 2003 | 07:09 PM
kd5kuu's Avatar
kd5kuu
The one with the lever is a vacuum operated motor to open/close one of the doors (vent door maybe? I can't remember off the top of my head).
xjcamaro89
2004 - 2008 F150
463
Feb 13, 2026 05:07 AM
grandpas1974
Apr 8, 2016 11:34 AM
Carmax
Nov 24, 2015 09:34 PM
Parsedout
20
Apr 12, 2015 12:18 PM
Zousha
Escape & Escape Hybrid
May 30, 2014 07:22 AM
