Driver door pull strap
Old May 29, 2015 | 05:14 PM
Richs66's Avatar
Richs66
Trailering
Hi, on my wifes 2013, doesn't have that strap to pull yourself in like the pass side...........anyone put one in aftermarket........im old and its getting harder and harder to get in that mother. LOL
Thanks
Rich
Old May 29, 2015 | 06:20 PM
NASSTY's Avatar
NASSTY
I don't believe anyone makes an aftermarket driver side grab handle for the 09-14 F150.
They brought back the driver side grab handle on the 2015 F150.
Old May 29, 2015 | 06:23 PM
muziclova's Avatar
muziclova
Always wondered why my 2014 didn't
have one.
thought it blocked the view,so they got rid of it.
Richs66's Avatar
Richs66
Trailering
Hey thanks Nassty, makes you wonder why they took it off in the first place. If only I was a few years younger I could just leap in that thing. LOL
Rich
Old May 29, 2015 | 07:24 PM
gDMJoe's Avatar
gDMJoe
Post
May want to consider adapting the following .....
*-Details- ««« -click-
-click- the pic'
Goth 150
< This space intentionally -blank- >
Old May 29, 2015 | 08:44 PM
Atlee's Avatar
Atlee
Sometimes it's nothing more than temporary stupidity. Or an attempt to save a nickel a truck.
More likely, who ever the designer was of the truck probably has no clue about F150's, doesn't drive one every day, especially 4x4's. To him it probably didn't seem important, since there is a steering wheel available.
Rich
Old May 29, 2015 | 09:47 PM
bmuhlbach's Avatar
bmuhlbach
I was thinking the same thing. I noticed the 04-08 have them on both sides.I wonder if you can pull one from the older year and if it will bolt in.
Old May 29, 2015 | 10:29 PM
Atlee's Avatar
Atlee
Don't know. One thing I do know is the running boards on the '05 F150 Scab will fit perfectly on the 20014 F150 Scab.
The 2014 HD pickup I got late last year did not come with running boards. My wife needed them to get in the truck, so our salesman measured both, and they were the same size, so he had them pulled off the '05 and installed on the '14.
Old May 29, 2015 | 11:45 PM
j.grif's Avatar
j.grif
I would suspect that they would install direct or very close to direct, that cab changed very little, I think the same cab from 04 to 2014, you may have to install nutserts in the a pillar where the handle mounts as the a pillar trim would not have any strength, very minor modification, hopefully this did not have anything to do with crash standards. The other factor is if the shape of the a pillar trim is the same through the years.
Old May 30, 2015 | 09:28 AM
gDMJoe's Avatar
gDMJoe
Post
bmuhlbach ... I noticed the 04-08 have them on both sides.I wonder if you can pull one from the older year and if it will bolt in.
They (the gen' 11 A-pillar grab handles) will NOT fit the 2009-2014 (gen' 12) F-150s. The A-pillars (and trim pieces) are different - mounting, angle, length.
The LH grab handle was re-introduced in the 2015 F-150s, however, don't know if they are/would be compatible.
-click- the pic'
Goth 150
Old May 30, 2015 | 09:31 AM
gDMJoe's Avatar
gDMJoe
Post
j.grif ... The other factor is if the shape of the a pillar trim is the same through the years.
It (the shape) is NOT the same.
Old May 30, 2015 | 03:26 PM
meborder's Avatar
meborder
FWIW, the strength of the column assembly was increased in '09 such that it is strong enough to be used as an entry aid. as such they removed the grab handle.
i just use the steering wheel on my 2010.
never thought twice about it.
on the expedition (06) i use the grab handle, as it is available and presumably, the column was not designed to be used for entry.
samwise2u
2009 - 2014 F150
34
Aug 28, 2015 01:23 PM
Growl60
Feb 16, 2010 10:41 AM
imfox
Alaska Chapter
Dec 30, 2008 06:37 AM
straight 6's
Sep 8, 2003 09:32 AM
