2003 Ford Explorer XLT Problems
Old May 28, 2015 | 06:22 PM
whispertg18's Avatar
whispertg18
Truck worked fine until I ran it almost out of gas...Now it dies at stop lights and anytime it's put in park. It doesn't go over 20 mph for the first minute after I push on gas. Doesn't seem like it's transitioning gears well and shakes a lot. Diagnostic says there is an EGR valve issue ,an O2 sensor problem and random misfire issues. Just want to know any opinions of what else it could be so I can know where to start.
Old May 29, 2015 | 12:14 AM
85e150's Avatar
85e150
Welcome to FTE.
You should probably be in the Explorer forum, and you should say what engine.
Generic advice:
Check the EGR. Check for vacuum leaks in the intake, especially o-rings that seal the intake to the heads.
O2 sensor codes are often other issues like the intake leaks. Misfires will also result from intake leaks.
You may also want to do a fuel pressure test.
Follow the codes, and learn the meanings. An O2 code does not mean you need a sensor.
Andy Chambers
Feb 14, 2017 07:11 AM
MemOrex
80
May 29, 2008 09:04 PM
Reiner
Nov 5, 2003 04:13 PM
au_scratch
May 24, 2002 07:22 AM
pstapler
Jul 5, 2001 06:22 AM
