help with stalling 302 please
Old Nov 17, 2003 | 12:46 PM
  #31
bremen242's Avatar
bremen242
Thats cool.. You shouldn't have to replace your motor mounts on the frame, they should have 289-302-351W stamped into the bottom. I'm not sure if the rubber mounts are the same or not.
You should hook everything to pass emissions if needed. You might have to get a new y-pipe for the 351W, as it is wider on top. You can get rid of the whole AIR system, but, again, emissions .
Make sure you get a 351W flexplate/flywheel for your tranny, 302s of that year are different.
Old Nov 17, 2003 | 02:04 PM
  #32
rwmedia's Avatar
rwmedia
new flexplate - what about ignition?
Have the new flexplate. Do I have to change distributors? and is there anything else (computer, wiring harness, etc.) that comes to mind?
Old Nov 17, 2003 | 05:11 PM
  #33
bremen242's Avatar
bremen242
I am not 100% familiar with 87+ years, but I believe you will have to change the computer to one from a 351W, and get a 351w from 88 to 92,93 (before they changed to MAF). 87 won't work, they were carb'd.
Old Nov 28, 2003 | 08:36 PM
  #34
rwmedia's Avatar
rwmedia
and now the exhaust
So - have the tranny and torque converter rebuilt, transfer case almost done. There is a crack in the exhaust manifold so I'm thinking maybe headers instead of replacing the manifolds. Doug Thorleys fit and have the quality I'm looking for but with lifetime guarantee they're over $900. Anyone know of a good quality header for a 351W that will last more than a few years without burning out that isn't that much?
Old Nov 28, 2003 | 09:01 PM
  #35
90f150moneypit's Avatar
90f150moneypit
From Hedman's site - HEDMAN'S HTC COATING IS GUARANTEED against external rust-through for a FULL 5 YEARS. Together with Hedman's Lifetime guarantee against defects in workmanship, you will have years of worry-free hedder ownership.
Hedman Elite
Old Nov 28, 2003 | 09:03 PM
  #36
bremen242's Avatar
bremen242
Hedman has good headers, but I couldn't get their long tubes to fit with my C6 on my 85 f-250. Just a thought: get shorties.
Old Nov 28, 2003 | 09:07 PM
  #37
90f150moneypit
I believe he has an AOD for the '90. Many people are using long tubes on these trucks.
Old Nov 28, 2003 | 09:12 PM
  #38
bremen242's Avatar
bremen242
I'm sure its possible, just mentioned it, since I sent back 3 sets of different long tubes that wouldn't fit my C6.
Old Nov 28, 2003 | 09:25 PM
  #39
rwmedia's Avatar
rwmedia
what about hooker or dynamax
My local garage suggested Heman as a possibility. Hooker has a set of super competition headers that are shorties that are supposed to bolt right up to the stock exhaust. I have read some really good reviews about dynamax but don't know anything about them.
The one thing that scares me is the number of stories about headers that had to be bent or parts that had to be moved because of improper fit so thats a big issue.
Also, is there a significant advantage to ceramic coated?
Old Nov 28, 2003 | 09:54 PM
  #40
bremen242's Avatar
bremen242
A lot of advantage: they won't rot apart in 3 or 4 years, they don't rust, and they keep the underhood temperatures way down.
Dobies4life
Alternative Fuels, Hybrids & Mileage
20
Aug 13, 2019 05:12 AM
PaulsEdge
Jan 9, 2017 07:09 AM
Rejection_Man
25
Jun 10, 2008 11:37 AM
FordTrucksKickGM
Sep 6, 2007 09:21 PM
Mud Bone
32
Aug 19, 2006 10:49 AM
