OD cancel switch not working!!!!
Old Sep 5, 2001 | 06:49 AM
getu12's Avatar
getu12
Old Mar 12, 2002 | 03:06 AM
groundrat's Avatar
groundrat
My my this is frustrating. The other day I was doing a lot of in town driving. Everytime I got in the truck I would turn off the overdrive. After about a hour or so, the button stopped working while it was in drive. I could shift to neutral and then turn it off/on, but not while in gear. The next day I get in the truck, and the button doesnt work at all. I checked all the fuses and all of them were good. Is there a way to check the switch? Has anyone had this happen to them? Any help will be greatly appreciated.
BTW it is a 1994 F150, 5.0, 4R70W trans, 2WD. Thanks again.
Bill
Old Mar 12, 2002 | 09:46 AM
Pastmaster's Avatar
Pastmaster
The switches go out periodically. To remove it, you need to pull the little cap off the end of the shifter. And the lamp assembly slides out.
$15 at the dealer.
'93 F-150 loaded and modified!
Check my Gallery
Old Mar 12, 2002 | 10:46 AM
groundrat's Avatar
groundrat
Is there a special tool that is required to do this? Or can i just use as small flat head screw driver? Thanks for the help.
Bill
Old Mar 12, 2002 | 03:37 PM
Pastmaster's Avatar
Pastmaster
If you look at the shift lever, on the back side of it is a verticle opening that you can use a flat screwdriver to pop the top off and the "off" switch slides out. No need to unhook battery.
Check my Gallery
