Toyhauler modifications thread
#166
Received 6,742 Likes
on
Randy, I was able to clean mine from below. I had to stand on something to get up there. I considered turning the fan on and spraying the snot out of it with degreaser. But I figured with my luck I would have degreaser on every wall. It did take a long time, but the results were worth it. I had no idea that the fan blades were clear plastic.
#167
Received 4,012 Likes
on
I have GOT to do this on mine too... It is gross looking and I am sure that the automatic rain-close sensor is probably too dirty to work. Only problem is in getting at it. I can't get on the roof very easily and the ceiling is 8'8" up there so will need to balance on a small ladder or stool..
#168
on
#169
I put all LED lighting in mine as well... But .... Living in it full time for 5 months, slowly they (LEDs) started failing... Other than the test of time, you just have to be able to see and not get headaches from them. There are some newer LEDs out now that have more natural light.
I just had to do it! LOL ! I'm sure you didn't cheapen out here but you Minnesotians!
Everybody wants Price - Performance - Quality but the stark truth is, you can only pick two of the three.. Always..
#170
How old is the date code on the tire?
Don't you just sometimes wonder how a tire can come apart so bad while the others still look good? Under inflation maybe. You know you probably didn't hit a puncture with a tire just ahead.
Hopefully no damage above.
#171
on
#172
Have since replaced them all with Maxiss M8008's. Used to always be in town, but had to order them in this time.
Got my solar metering all wired in. Panel output/controller output/ and trailer load/usage.
#173
#174
on
#176
Wow, looks like I have some fun to look forward to after our new TH shows up. Thank you Scott for pointing out this thread. I zipped through it real quick and already see some mandatory items on my list. This may be our first 5thr but not really our first TH. I did a Cargo conversion a couple years back, we enjoyed it several trips out but decided we were tired of being so cramp, plus our Scottie is demanding he get to go on our outings.
Here is a slide show of the Cargo Conversion. Trailer Cargo Conversion Slideshow by slyhuntr | Photobucket
#178
#179
on
Man that seems pretty light...
This guy with my SxS in it and a buncha tools we're heading south with - weighed in at 3600# and 660# tongue weight.. This Jeep does not tow it normally, I just hauled it across town and weighed it. Normally tow with either the SD or our Jeep Rubicon Unlimited..
This trailer is 6x12
I'd like to find a toy hauler that would come in at around 4000# loaded that would also have a toilet, shower and cook surfaces..
#180
That 1900# is what the empty weight was when delivered. After installing A/C, kitchen area, RR, bed I guess all that may have been about 1000#, maybe a bit more. Loaded with gear and RZR, I may have been loaded around 5500#. Originally we were going to tow with a 99' Durango with a 5.9 Liter engine, it towed it with air bag lift but it didn't like the hilly country. I decided I need more power and found the 01' SD with the 7.3L, glad I chose that truck as we have chose a different path.
