Running very rough when put into 'drive'
Old May 23, 2015 | 03:54 PM
TylerMcDonald's Avatar
TylerMcDonald
Exclamation Running very rough when put into 'drive'
I have a 1969 F100 2x4 with a 360 (Edelbrock intake, Holly 4BBL, Pertronix points eliminator kit) auto trans and power brakes and steering with a/c.
Yesterday I was puling out of a store that had a good dip in the exit before you hit level road again and once i hit the dip the truck died. I pulled it over and it started right up as usual. When I put it into 'drive' it ran VERY rough. I changed the coil and the pertronix kit and no better. I have also recently changed almost all of my ignition and electrical components recently.
I believe I have a vacuum leak somewhere but am not sure where. I recently replaced all the vacuum lines ran off of the carb as well. Where should I look?
It idles normal in park and neutral but runs very rough (and with no power, and I have to keep my foot half way in it to keep it from dying) when it is in drive or reverse. Any help would be greatly appreciated! This is my daily driver so I would love to get it on the road asap. Thanks y'all!
-Tyler
Old May 23, 2015 | 08:22 PM
ultraranger's Avatar
ultraranger
-Tyler
Hard to say what the problem might be. Could be most anything. You said you suspect a vacuum leak. If the vacuum lines on the engine are good, there is one more place where there's a vacuum line you wouldn't see from topside --the vacuum line attached to the modulator on the transmission.
The other end of the transmission vacuum line connects to the intake. If the jolt was hard enough, maybe it knocked the line loose from the modulator (?) --just a guess.
Old May 23, 2015 | 09:04 PM
TylerMcDonald
I'll look at the transmission vacuum line tomorrow. Thank you for he suggestion. That would have never have occurred to me.
Old May 24, 2015 | 01:05 PM
TylerMcDonald
I checked out the vacuum line and fitting off of the trans and it seemed fine; not loose or anything.
I'm most curious as to which vacuum lines engage when it gets shifted to drive? This would help narrow down my options to focus on.
Thank you for all of your help.
-Tyler
Old May 24, 2015 | 05:09 PM
kenny nunez's Avatar
kenny nunez
rough running
You may have some water or dirt rolling around inside of the carburetor that got loose.
Old May 25, 2015 | 12:42 AM
TylerMcDonald
I just rebuilt my carb so I don;t think its dirty. I suppose that it could be a possibility. I also made sure today that my floats weren't stuck.
Old May 25, 2015 | 11:40 AM
tasboj's Avatar
tasboj
It sounds like the choke is not opening or stuck,this is the symptom that happens to me wen I forget to pull out my manual choke,
TASBOJ............................
Old May 25, 2015 | 11:41 AM
kenny nunez
running rough
Try this, Have someone hold the brakes and put it in gear, try pulling one plug wire at a time to see if it is a dead cylinder. Also remove and plug all vacuum ports to be sure there are no leaks.
Old May 25, 2015 | 05:30 PM
orich's Avatar
orich
Have you checked the dizzy vacuum advance for a leaking diaphragm.
Ya never know when one will fail. May be a can of quick start and spray it all around the carb base & vacuum lines. Recheck your timing could be timing jumped from loose timing chain from the dip in the road you hit.
orich
Old May 29, 2015 | 01:33 PM
TylerMcDonald
I just pulled my sparkplugs and the 4 closest to the firewall were all soaked in oil. I will replace all of my plugs and report back. I'm curious why it was just the rear ones (#'s 6,5,1 and 2)
Old May 29, 2015 | 03:36 PM
TylerMcDonald
Whoops read the diagram backwards. The other 4 plugs are the ones covered with oil.
I changed them all out and it certainly liked that more but it still sounds like its missing a cylinder. My wires are new as is my coil, cap, and rotor.
Any thoughts?
Old May 29, 2015 | 04:49 PM
351Cleveland C4's Avatar
351Cleveland C4
Valve springs! Haha
No probably not. You say it's running bad only when it's in gear? Do you have a tachometer and a vacuum gauge? With those two instruments you can solve a lot of problems. I'm also leaning towards the vacuum leak possibility.
Old May 29, 2015 | 05:25 PM
JEFFFAFA's Avatar
JEFFFAFA
I think if you find where the oil on those plugs came from you'll solve you running problem. If I combine vac leak with oil I think intake gaskets bad or PCV system not plumbed right.
Old May 29, 2015 | 06:17 PM
itsabullitt's Avatar
itsabullitt
Does it idle high when in neutral? I have a vacuum port on my chevy pickup that just has a rubber cap over it. When the cap came off it idled much higher in neutral and was very rough running to the point of dying when in gear. I discovered this pulling into my parking lot at work. Barely made it off the street. Plugged the vacuum port and was good to go. Sounds almost entirely like what you've described.
Old May 29, 2015 | 06:19 PM
itsabullitt
I'm thinking the same.
