Remove coolant before adding VC-12.
Old May 20, 2015 | 06:48 PM
tgtrotter's Avatar
tgtrotter
Howdy,
19,000 miles/ 10 months and the correct 3 in 1 strips from Accustrip show both radiators (yes i did drain from side/cold radiator ) less than 5ppm (yeloowish tan) on nitrites and dilution good 50/50. The secondary contamination test came good.
My two questions are (1) Does this not seem early for additives ? (2) Do I remove 32 ounces from the radiator before adding ? And same for the air coolant but 16 oz. ? The reason I ask is both resrvoir/degas bottles are full cold and adding more liquid ???
I wish I could just screw on a need release filter like my big rig has...
For now Im gonna finish up fuel filters and wait for replies. Thanks for input. Safe weekend.
Tim
Old May 20, 2015 | 07:26 PM
69cj's Avatar
69cj
If it was my truck, I'd just do a drain and refill with new coolant. Why screw with it. JMHO.
Old May 20, 2015 | 10:32 PM
Painted Horse's Avatar
Painted Horse
I'd just take out enough so you don't over fill and put in the VC-12. You can add it twice during your coolants life ( 105,000 miles)
Old May 20, 2015 | 10:58 PM
CarlT100's Avatar
CarlT100
Good information. Painted Horse. My check coolant additive message just came on at 103,000. I will wait until I get back to Florida and change the coolant.
Old May 26, 2015 | 11:31 PM
tgtrotter's Avatar
tgtrotter
Guess I better do my homework. Less than 5ppm nitrates is what the OAT coolant is. Zero nitrates. Did not need to add VC-12. Found this info on another forum and also when it does need the additive, (by results of the secondary condition test) to not overfill. Drain as necessary. Maybe this helps someone.
Old May 27, 2015 | 04:57 AM
senix's Avatar
senix
Here you go.
File Type: pdf
3000gtman
15
Nov 23, 2016 06:48 AM
bizzelj
Jul 29, 2015 09:26 PM
MandolinMan
Jan 17, 2014 10:50 PM
white-horse
Aug 6, 2013 10:12 PM
Javo
Mar 26, 2011 11:42 PM
