Need wiring help
Old May 20, 2015 | 04:20 PM
GM4WALLS's Avatar
GM4WALLS
Need wiring help
Swapped the bodies on the truck last weekend. Truck would not start, had to rewire the ECM. Now, truck starts, but does not shut off with ignition switch. In order to shut the truck off you have to disconnect the neg wire from the battery. I know the alt is not wired yet.
New ignition switch, third one... Eliminated as problem.
New solonoid, third one... Eliminated as problem.
I feel this is definitely something done in the wiring.
1977, 300 6cy, AT.
Old May 20, 2015 | 04:26 PM
bkaul's Avatar
bkaul
Sounds like the ECM wire that should get power only in start/run is hard-wired to a constant power source. May be that you got it and one that's supposed to get constant power swapped.
Old May 20, 2015 | 07:04 PM
GM4WALLS's Avatar
GM4WALLS
Checked that, doesn't seem to be the case.
Old May 20, 2015 | 07:25 PM
brian1080's Avatar
brian1080
*missed it, just re-read.
There is only one way the truck stays running, the wire on the dist is still getting power. Does it start like normal? when it is off with the battery connected, is it draining power? Are you sure the wires are correct on the solenoid?
Old May 20, 2015 | 07:38 PM
ZarK-eh's Avatar
ZarK-eh
What brian1080 said, but also check the ECM wire too with a voltmeter!
FYI, the coil wire should be attached to the I terminal on the starter solenoid/relay. It's what supplies full voltage to the coil for easy starts. And when running, coil is fed voltage through a resistor wire (about 8 volts).
The 3 wire plug:
1 wire (32 Red Blue) has power during start, and is the same wire that energizes the starter solenoid/relay.
1 wire (732 White) has power with ignition key in run.
If any of these are messed up, then you might have the symptoms you describe. If these wires are right, then the engine will stop when the key is off.
Old May 20, 2015 | 08:06 PM
GM4WALLS's Avatar
GM4WALLS
The starter is continuously engaged as well if that helps.
Old May 20, 2015 | 08:25 PM
bkaul's Avatar
bkaul
Any other relevant details you haven't included yet?
If you pull the little wire off the S terminal on the starter solenoid, does it stop? If so, you've got a wiring problem feeding the solenoid or a bad ignition switch; if not, you've got a bad solenoid.
Old May 20, 2015 | 08:36 PM
GM4WALLS's Avatar
GM4WALLS
Definitely wiring. Yeah, engine does when you pull the wire off the S terminal.
I will check all this tomorrow and get back to you guys.
Old May 22, 2015 | 12:17 AM
ZarK-eh's Avatar
ZarK-eh
Looks like we found the problem that fits the symptoms!
Mixed up "I" and "S" on Start Solenoid/Relay.
Old May 22, 2015 | 07:21 AM
GM4WALLS's Avatar
GM4WALLS
I and S cannot be switched, the truck will not start unless they are correct.
Old May 22, 2015 | 08:49 AM
bkaul's Avatar
bkaul
It should: the wire that should go to the I terminal ties in to the coil power feed after the resistor wire. If it gets hooked to the S terminal, then the starter solenoid will see ~8-9V when the ignition switch is in the run position - which should be enough to actuate it - so it'll be continually cranking with ignition switch in run.
Then, if you put the terminal that should go to S on I, it would be getting backfeed of +12V when the starter solenoid is activated; I'm not sure exactly how your wiring is set up, but there would be a feed from the ignition switch start position to the ignition module (and/or ECU in a fuel-injected setup) so that the engine can fire while cranking in order to start. Hooking the wire that should go to the S position to the I terminal is what supplies this circuit.
Easy enough to test whether that's what actually happened: swap 'em and see.
Old May 22, 2015 | 08:55 AM
GM4WALLS's Avatar
GM4WALLS
I swapped em, the truck will not start with them swapped. I have more time today to fool with it, four day weekend!
Old May 22, 2015 | 09:01 AM
bkaul's Avatar
bkaul
OK, was worth a try - would've been a simple fix!
Does the truck start cranking as soon as you turn the ignition switch to run, or do you have to go all the way to the start position?
Old May 22, 2015 | 10:39 AM
GM4WALLS's Avatar
GM4WALLS
As soon as you put it in the start position. Right now the alt is not hooked up, so the only way to shut it off is to pull the negative terminal off the battery or the S or I wire.
Old May 22, 2015 | 11:54 AM
bkaul's Avatar
bkaul
I wonder if the S wire is somehow being backfed by the I wire... such that once you start cranking, it'll keep itself on.
