Help!!!!!!
Old May 25, 2015 | 07:13 PM
High76boy's Avatar
High76boy
Ok so I tried a few things I can plug the number 2 injector plug in the number 4 injector and it still runs fine just missing on the 2 cylinders and when I plug the number 4 into the 6 cylinder it quits firing on 1-4-6-7 again so that tells me the injectors are fine it's a issue in either the harness or ficm correct?
Old May 25, 2015 | 07:35 PM
Snowseeker's Avatar
Snowseeker
Did you try plugging number 6 into the 4th injector just to see what happens?
Does very well sound like harness or something else though.
Old May 27, 2015 | 06:12 PM
High76boy's Avatar
High76boy
I did not pull the injectors out no matter what I get the same result if I plug the number 4 plug into the 6 injector so that's telling me there is a issue coming from somewhere else
David Fehir
Sep 18, 2017 07:55 PM
W Mac
Jun 21, 2015 05:35 PM
ROBBINthaHOOD
Nov 11, 2014 09:24 PM
SilverSS
13
Jan 5, 2014 11:51 AM
ColonyPark
19
Jul 29, 2005 01:20 AM
