vin help?
Old May 18, 2015 | 01:25 PM
greentruck72's Avatar
greentruck72
vin help?
need some VINS deciphered to see what actual came with my trucks
- 1973 f100
f10YKQ48083
133 6BF 101 2 4 G025
-1972 f250
f25YKN66688
131 u F250 1 4 G38
I know hat some of the numbers mean but not all
Old May 18, 2015 | 02:05 PM
bkaul's Avatar
bkaul
Here you go - a link from one of the sticky threads:
Decoding '73-'79 Ford Truck VIN Tags - FORDification.net
Old May 18, 2015 | 02:06 PM
greentruck72
NumberDummy could you take a look at these when you get time?
Old May 18, 2015 | 02:14 PM
greentruck72
thanks bkaul your always pretty quick with those and they help a lot.
Old May 18, 2015 | 02:15 PM
bkaul's Avatar
bkaul
No problem.
Old May 18, 2015 | 02:23 PM
greentruck72
I messed up on the 73's end it 02J not 025
Old May 18, 2015 | 02:25 PM
greentruck72
where would I go for the 72 one does the link have the older ones?
Old May 18, 2015 | 02:28 PM
bkaul's Avatar
bkaul
The same people do, but for some reason, they use separate domain names: .com for '67-72 and .net for '73-79.
Technical Articles Index - FORDification.com
greentruck72
that web site said I have a 3.00 gear ratio that's small in my opinion/ unless i'm a complete idiot and can decipher anything worth a darn
Old May 18, 2015 | 02:45 PM
greentruck72
oh my computer is slow the post for the other link didn't show up till now.
Old May 18, 2015 | 02:51 PM
greentruck72
thanks for that help
Old May 18, 2015 | 03:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by greentruck72
need some VIN's .. Warranty Plates deciphered to see what actual came with my trucks
1973 F10YKQ48083 / WB: 133 / COLOR: 6B / MODEL: F101 / BODY: 2 4 / TRANS: G / AXLE: 02J / MAX GVW LBS: 4650 / DSO: 53
F10 = F100 2WD Pickup.
Y = 360 2V
K = Kansas City MO Assembly Plant.
Q48083 = 1973.
133" Wheelbase.
COLOR 6B: 6 = Bright Medium Blue / B = Light Blue.
F101 = F100 2WD Pickup .. 4,650 lbs. GVWR
2 4: 2 = Light Blue & Medium Blue Vinyl - 81A Custom / 4 = Styleside Pickup.
G = C6.
02J: 02 = Ford 9" Rear Axle / 3.00-1 / 3,300 lbs. Rear Axle Capacity // J = Power Steering.
4,650 lbs. Gross Vehicle Weight Rating.
DSO 53: Kansas City MO District Sales Office, where the original selling dealer ordered the truck from.
1972 F250 / F25YKN66688 / WB: 131 / COLOR: U / MODEL: F250 / BODY: 1 4 / TRANS: G / AXLE: 38 / MAX GVW LBS: 7500 / DSO:
Geez Louise, what a mess! Some of the codes were out of sequence / 1973 MODEL code missing the F / trans/axle codes typed together / some of the codes are missing.
Where in the sequence of the Warranty Plate does 6BF belong?
F25 = F250 2WD
Y = 360 2V
N66688 = 1972.
131" Wheelbase.
U = Lunar Green.
F25 = F250 2WD .. 7,500 lbs. GVWR
1 4: 1 = No such code as 1 / 4 = Styleside Pickup.
G = C6.
38 = Dana 60 Rear Axle / 3.73-1 / 5,250 lbs. Rear Axle Capacity.
7,500 lbs. Gross Vehicle Weight Rating.
DSO:
Old May 18, 2015 | 03:17 PM
greentruck72
yeah I wrote them down wrong and didn't go back and check, the axle number off the 73 f100 is 02J - which from what I found is ford 9" with LSlip with a 3.00 ratio, the color code of the 73 is 6BF
Old May 18, 2015 | 03:40 PM
NumberDummy
which from what I found: 02 = ford 9" without LSlip with a 3.00 ratio / J = Power Steering.
The color code of the 73 is 6BF
No it isn't.
COLOR code contains a single digit or 2 digits if tu-toned.
1959 thru today: If the AXLE code begins with a letter: Limited Slip / If with a number: No Limited Slip.
Old May 18, 2015 | 03:57 PM
greentruck72
i removed the pic
