starts with command start. key does nothing
Old May 16, 2015 | 02:15 PM
dangerelectric's Avatar
dangerelectric
Hello I have a 2012 drw 4x4 crew cab long box 6.7 and woke up today and my key buttons worked lock, unlock, and command start. But putting my key in ignition does nothing. I am 2 hours in the woods on a camping trip, I need ideas before I pay 500+ for a remote tow call.
Battery voltage is 12.3
Everything seems to work just the ignition does nothing.
Please help.
Old May 16, 2015 | 04:08 PM
Specularius's Avatar
Specularius
Do you have the other key to try? Might be something with the RFID chip.
Old May 16, 2015 | 04:36 PM
IDDiesel's Avatar
IDDiesel
With the key turned on can you shift into gear?
The first thing electronic tech support does is disconnect the power. disconnect both batteries and hope for a reset.
At least your smart phone is working.
Good luck!
Old May 16, 2015 | 04:47 PM
dangerelectric
Well I feel like an idiot. Fuse 28 inside the cab. Thanks for all the help, I wish I had checked the fuses first off but as soon as I googled the issue there were so many threads about bad batteries and computers failing that I just went to worst case scenero.
Old May 16, 2015 | 05:41 PM
IDDiesel's Avatar
IDDiesel
Always nice to find something "wrong" when troubleshooting. Glad it was just a fuse.
Old May 16, 2015 | 07:23 PM
Dakster's Avatar
Dakster
Glad it was a fuse too!
Old May 16, 2015 | 08:25 PM
Specularius
I would still be concerned though. A fuse blows for a reason.
Old May 16, 2015 | 09:41 PM
dangerelectric
I still plan to get it looked at. Just on my terms now and not a huge tow bill to get me out of the bush.
Thanks!
Old May 16, 2015 | 11:48 PM
Dakster's Avatar
Dakster
Being out in the bush, was this a rough ride? Possible that you could have giggled something loose and it shorted out. But now that you are 'stationary' it's ok...
I hope you can figure out why it blew a fuse, but happy you should be able to get out without a $500 tow bill...
Old May 17, 2015 | 10:46 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
YES......A queer electron got in the circuit and blew the fuse.........
8e3k0
6.7L Power Stroke Diesel
Dec 30, 2017 04:59 PM
kornfanjoe
Apr 1, 2012 03:58 AM
ScottInTexas
1997 - 2003 F150
May 9, 2008 04:11 PM
Spotty
1997 - 2003 F150
Apr 11, 2007 08:52 AM
BigDfromTN
2004 - 2008 F150
Feb 9, 2007 03:10 PM
