Australia Chapter Join Chapter , Leader: OPEN
Got a Problem
Old May 16, 2015 | 02:51 AM
ChunderDownUnder's Avatar
ChunderDownUnder
Got a Problem
http://vid104.photobucket.com/albums...ps1idqomyh.mp4
Old May 16, 2015 | 09:13 PM
Aussie BrianB's Avatar
Aussie BrianB
Brian,
"Got a problem"
Bit of an understatement!
Going to be spending a bit of time getting your hands dirty I expect.
How is the other side?
Old May 16, 2015 | 09:27 PM
ChunderDownUnder
the other side does have play but not as bad. the play in the axle tube has me concerned tho. Its all undone,just having a smoke before I get the hammer out to get the hubs off.
Old May 16, 2015 | 09:37 PM
Aussie BrianB
I can think of a lot of better ways to spend a Sunday.
Best of luck with it.
Old May 16, 2015 | 09:55 PM
ChunderDownUnder
it gets better
http://vid104.photobucket.com/albums...psgiwy5ruk.mp4
Old May 16, 2015 | 10:20 PM
Aussie BrianB
Ouch!!
Going to be spending more than Sunday on that by the loook of it.
Old May 17, 2015 | 06:40 AM
Aussie BrianB
Brian,
Have you found what bit has given up the ghost yet?
Old May 17, 2015 | 05:58 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
I am guessing the wheel bearings are gone for one, but with the play on the axle shaft I am guessing the bearings in there are gone too (and probably the seals as a result). IIRC they are needle roller bearings.
How many k's you got on your truck Brian?
Old May 22, 2015 | 06:48 AM
Patchy 73's Avatar
Patchy 73
Mate, tried the link nothing comes up
Cheers,
Patchy
Old May 22, 2015 | 07:43 PM
ChunderDownUnder
Do you have Windows Media Player. ?? Im assuming thats the problem.
Adrian. I have 225000 Kms. The drivers side bearing is toast. I could here some grinding while driving, thats what started the tear down. Im going to replace both sides and the needle bearings in the front diff. I cant seem to get the axle out at this stage. From what I read its a matter of hitting the back of the Uni joint but it aint working. Any ideas ??
Old May 23, 2015 | 09:51 PM
ChunderDownUnder
what i think has happened is the vacuum seal has work it way through the housing towards the axle tube. Its a rock hard seal and wont push through because now its getting caught up on the inside lip of the housing.
Old May 23, 2015 | 11:36 PM
ChunderDownUnder
Here is the vacuum seal in question
and this is what I had to do to get it through
Old May 24, 2015 | 07:40 PM
BigF350's Avatar
BigF350
FTE Emeritus
You should be able topry the axle shaft out with a couple of big screw drivers on the lip like here:
225,000km is pretty early for them to fail. If you aren't planning on it already, I'd replace all the seals too, they get shot real quick after the bearings fail.
Old May 25, 2015 | 02:14 AM
ChunderDownUnder
If only I had a pry bar. Mine is in the work truck which is not here. Anyways its out now. Now u say all the seals. I have the axle tube dust seals, the vacuum seals, what else. ?? Your not talking about the oil seals in the diff ??
Old May 25, 2015 | 03:11 PM
Blue7.3's Avatar
Blue7.3
You only need the three seals , the axle seal FORD F81Z-3254-CB, SKF the big yellow one FORD F81Z 4A322AA and the axle dust seal FORD F81Z-1S175-HCA, plus you'll be fitting new needle roller bearings FORD C6TZ-3123-A , if you have auto hubs it may pay to re-new the o-rings on the auto hub assemblyFORD 4C3Z-1K106-AA.
