I am looking for headers for a 1968 ford f100 with a 351 windsor and a 4 on the floor manual transmission. Does any one have any pointers on a good set or where to look?
As you may know the 351W was never offered in this series. A few FTE'ers in the past have navigated the uncharted waters but no one to my recollection has ever documented what worked and what didn't.
Welcome to the forum amigo, and by your moniker, I see you are 101st. Thank you for your service. Lots of us on this site are former military. Brothers in arms are here, as well as lots of patriots.
I THINK 302 headers will fit. Worth a try for sure. You can buy a set from summit or jegs and if they don't fit you can send them back.
I tried this on a 69. The deck is higher on the 351W and the collectors would not clear the 11" bell housing. If you had an auto or the 10-1/2" bell housing I don't think you would have a problem. I tried three different brands an none would clear. I bought a set of shortys and the left one wouldn't clear the clutch bell crank pivot.
The 351W having a one-inch taller deck height than a 302 will likely require splaying out the collectors to clear the bell. Meaning, the head tubes need to be angled outwards to produce the required clearance. I'd prolly pie-cut the head tubes, splay them out, and re-weld.
Perhaps 351W headers for 88 (?) to 96 *might* be better candidates?
The 351W was first put into the Ford trucks in 1980.
I don't know how close the Bullnose ('80-'86) frames are to a Bumpside but, may be dimensionally closer than the '87-'96 frames (?).
One major difference I'm aware of is the placement of the steering gear box. On a Bumpside, it's behind the crossmember. On a Bullnose, it's located in front of the crossmember.
I'm heavily kicking around the idea of fuel injecting a 351W I have so, this is something I'm going to have to work out with my '69 F100.
Also referred to as "rear-steer" vs "front-steer", respectively
I have a 351W in a 68 with a c4. I tried some shorty headers that were for a GT Mustang. The drivers side was right against the power steering box (from a 76) and I thought the heat might cause a problem so I didn't use them.
The 72 came with a 302 or so I have been told so ordered a set of headers for a 72 with a 302 and a standard transmission. I will give them a try and let you guys know what happens! Should be in sometime next weekend.
Baja
Yes I am in 101st. Thank you, im glad to see so many veterans on here.
I used JBA long tubes for 65-79 mustangs because of the bigger 1 3/4 primaries and being stainless steel. I had to modify my z bar by moving it back about 2-3 inches, and spaced the motor up 3/16 to clear the steering box. All of this is with a 302 block though. Curious to see your results.
I have a 351W in my 71. I do not know the brand, but I will tell you they point right at the transmission cross member. The result is an awkward exhaust pipe.
Reason: not done
