Rusting rockers/ cab corner help
Old May 14, 2015 | 05:15 PM
Golden210's Avatar
Golden210
2005 f150 crew cab. Alright here's the deal my rockers underneath by the cab corner are gone, corners are going too. I don't want to replace the hole rocker panel. Any ideas? Almost like I only need half the rocker. Anyone use fix my rust stuff? Do they slip on the old ones or have to cut the entire thing out. Any help would be great thanks!
Old May 15, 2015 | 02:23 PM
Beechkid's Avatar
Beechkid
I have not heard/used "Fix my rust" stuff.....IMHO, you first need to strip the paint, etc. off to see what the real extent of the damage is, then cut out the bad and weld in the new.
Old May 16, 2015 | 09:25 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Unfortunately, the only way to fix the rust, is to have it cut out, and new metal put in. There really isn't any good alternative.
Old May 16, 2015 | 04:54 PM
Golden210's Avatar
Golden210
Yea I knew I would have to cut the rust out. It's not the whole rocker so I but would be kind of hard to make a piece of metal out of scrap. I may order the whole rocker and maybe just use half of it. See if that works.
Old May 16, 2015 | 06:21 PM
GlueGuy's Avatar
GlueGuy
I am so glad I moved to a place where the don't put corrosive stuff on the roads...
Jabohlen
Aug 3, 2019 02:07 PM
LesPaul
Aug 12, 2015 10:05 PM
Golden210
2004 - 2008 F150
May 16, 2015 08:31 AM
shore
1997 - 2003 F150
15
Mar 2, 2014 10:07 PM
69Black250
May 31, 2009 08:33 PM
