I have an 85 Bronco that I have just replaced the rotors, calipers,new master cylinder and outside lines on and. after bleeding many times still can't get a peddle or brakes. Can't find a leak anywhere.? HELP ! I M STUMPED
Since my first post we have changed the master cylinder again after bench bleeding.. replaced the perportional valve(new) and have bleed the brakes till we're blue in the face. . No peddle ..I'm puzzled about this one !
It sounds like you have some air trapped in the lines somewhere and isolating each set of brakes independently as described in one post can possibly help you find the problem line.
If you've bench bled the master cylinder and you know it is in good condition and if all your lines are in good condition with no leaks and the rubber sections aren't ballooning then you likely have some air trapped. Good luck
