It needs a radiator which is totally plugged so it only runs for about 4 minutes before it boils. I'm strapped out working on my 47 panel so hoping for a radiator to drop from above.
I am changing out my radiator .you can mine but it is a 31. Don,t think it will work in your 29
I had a fan blade snap and go through it. I had it repaired but it is leaking. I have a replacement for it. If it is good and you think you can make it work I will send it your way
