bad blow by?
Old May 11, 2015 | 04:15 PM
EMT-I's Avatar
EMT-I
bad blow by?
Early 99 7.3. Runs ok has a slight miss at idle however every injector when unhooked makes a change. Has white and blue smoke From the exhaust. Has enough blow by to blow the oil cap off as your unscrewing it. My question is, I know engine restore is bad for these trucks but I can't afford to rebuild the engine. If I run the restore and then clean the IRP once the truck dies is this going to mess anything else up. Do you think it will by me a few months to save up for a rebuild
Old May 11, 2015 | 04:29 PM
CampSpringsJohn's Avatar
CampSpringsJohn
What does the fuel filter look like? Is it black?
Additives of any type is very hard on these motors.
How many miles are on your truck?
Have any modifications been done to it?
What kind of oil are you using now? What oil weight?
Old May 11, 2015 | 04:32 PM
EMT-I's Avatar
EMT-I
Unsure on the miles, odometer quit at 140k. Ebpv delete. Crankcase vent rerouted. All the injectors were replaced with remans in October. Oil is Rotella 15-40
Old May 11, 2015 | 04:33 PM
EMT-I's Avatar
EMT-I
Oh and fuel in the bowl is clear
Old May 11, 2015 | 04:49 PM
CampSpringsJohn
So you know where I was going with that question. The new injectors and o-rings should have eliminated that as a possibility. The thing with adding stuff to the oil is that it may cause it to foam up in the HPOP system. The original Lucas engine additive did that. They do make one specifically for Powerstrokes, but I have not heard anything good or bad about it.
Old May 11, 2015 | 04:56 PM
EMT-I's Avatar
EMT-I
Yeah. I was going to run a compression test cause I suspect #7 is low as that injector makes the least difference in the idle. However I broke the adapter I built to reach the glow plug hole so I need to replace it before I can do that.
Old May 11, 2015 | 08:40 PM
crop harvester's Avatar
crop harvester
Double check the crank case breather plumbing for restrictions.
Old May 11, 2015 | 09:57 PM
EMT-I's Avatar
EMT-I
Crankcase vent blows out the back of the truck free. And alot of white smoke from the vent
Old May 12, 2015 | 02:38 PM
holeshotwalt's Avatar
holeshotwalt
If the truck runs well, I'd just keep driving it and not do any additives (to the oil). Anything in a bottle isn't going to help a mechanical problem! Save your money for the rebuild.
Old May 12, 2015 | 03:09 PM
EMT-I's Avatar
EMT-I
Ok well I did it. Added the restore. Truck still running, smoke is almost completely gone. Obviously it still needs a rebuild but at least now when I'm driving down the road I can see behind me instead of just a cloud. Thanks for the replies
dothedew192
Jul 7, 2017 08:16 PM
jgrohs54
Sep 1, 2015 07:13 PM
bike_guy123
Nov 20, 2014 01:21 PM
KRAZY KRAMER
Apr 5, 2013 02:55 PM
F6Guy
Dec 28, 2011 03:40 PM
