Clunk/vibration
Old May 11, 2015 | 12:18 PM
Karruda's Avatar
Karruda
Clunk/vibration
Hey all I'm new to this website and also new to owning a truck. I'm a mechanic but work only on cars so I'm a little shy on diagnosing trucks. I have a 2001 7.3 f250 4x4 short bed, when I give it gas I can hear a clunk, when I let off of the gas I also hear a clunk. Also when traveling at high way speeds I can feel a strong vibration when I very lightly give it gas but the vibration goes away as I give it more gas. Any help is appreciated!
Old May 11, 2015 | 01:00 PM
montanasteve's Avatar
montanasteve
Check your driveshaft u-joints.
Old May 11, 2015 | 01:18 PM
Karruda's Avatar
Karruda
Will do! Much appreciated
Old May 11, 2015 | 01:21 PM
The Brad's Avatar
The Brad
I would also check the driveshaft carrier bearing. The rubber isolation could be shot.
Old May 11, 2015 | 02:59 PM
F250_'s Avatar
F250_
One last item is the splined slip yoke joint on the drive shaft... probably needs a little lube, which is more than likely what is causing the clunk.
Old May 11, 2015 | 07:49 PM
Karruda's Avatar
Karruda
Replaced the 2 u-joints on my rear drive shaft and lubed the slip yolk, drives like a new truck! Thanks all
Medicman78
Dec 11, 2013 06:03 PM
aws3230
Jul 27, 2008 11:02 AM
beekermartin
1997 - 2003 F150
Feb 7, 2007 08:48 AM
dallas lewis
1978 - 1996 Big Bronco
Mar 20, 2006 03:46 PM
dvldog458
Feb 5, 2003 06:13 AM
