6.2L V8 Discuss the 6.2L V8
Fan operation..
Old May 10, 2015 | 04:01 PM
clintbonnie's Avatar
clintbonnie
Fan operation..
Is it normal for the engine Fan to come right after a cold start ? It stays on for a few minutes and stops.. Don't see the logic in that..
Old May 10, 2015 | 04:20 PM
ATP Pilot's Avatar
ATP Pilot
mine does the same thing, others have said so too.
Old May 10, 2015 | 09:08 PM
Pit Crew's Avatar
Pit Crew
Same here and I hate it. I never heard the fan in my last three trucks. Some times it willstay on for 5miles or more. If I really get on it, it will stop.
Old May 10, 2015 | 09:30 PM
dave7200's Avatar
dave7200
Everyone that has posted has a newer super duty, as do I. Mine is a 2015 and I wondered as well why the fan makes so much noise when the motor is cold? The part I also don’t understand is the fans in our trucks is a mechanical fan, so how can it make more noise at any other given time since it just runs off the belt unlike an electric fan most new vehicles have.
Old May 11, 2015 | 06:33 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Fan operation..
It has a clutch that let's it free wheel when it isn't needed, why they lock it up on cold starts is a mystery. If you pull it hard on a hot day the clutch will engage and you will really hear it until the temp comes down.
Denny
Old May 11, 2015 | 08:03 AM
ATP Pilot's Avatar
ATP Pilot
The clutch is electrically controlled.
Old May 11, 2015 | 08:47 AM
airm4n's Avatar
airm4n
Could be testing the fan by running at startup. Would be nice if you found out your fan doesn't work a couple miles from home rather than climbing the largest hill in the area? . The semi's I used to drive would kick the fan on in the morning as well so I never really thought much of it. They are air operated clutches though.
Old May 11, 2015 | 04:01 PM
Good listener's Avatar
Good listener
Check out this thread if you are interested in a clutch fan replacement: https://www.ford-trucks.com/forums/1...onversion.html
Old May 15, 2015 | 11:37 AM
heymrdj's Avatar
heymrdj
I was told it was viscosity that makes that happen. Not sure it's the same for the electric clutch, but from what I can read it is: Fan Clutch Diagnosis - Engine Cooling System
Gertie-The '49 F2
Oct 5, 2015 07:40 PM
lazerf250
19
Oct 20, 2007 11:40 AM
Pablo-UA
Aerostar
Nov 13, 2005 08:20 AM
