Sponsored by: Auxito
Ghost wipers ???
Old May 10, 2015 | 08:20 AM
seastrike's Avatar
seastrike
Ghost wipers ???
my 2000 f150 does something weird... occassionally the wipers come on for no apparent reason. Also the odometer blanks out after a weird click sound in the dash... i have heard mention of the odometer thing. Does it do this indefinately or does it eventually shut off for good? Anyone have experience witht the wiper issue?
Old May 10, 2015 | 03:11 PM
enriched&beyound's Avatar
enriched&beyound
Have you had a lot of rain lately? Is it parked outside primarily?
I would make sure that the electrical grounds & connections are all good.
But...this maybe is a issue with a leaking front windshield, which allows water to eventually get to the GEM module
Old May 10, 2015 | 06:33 PM
seastrike's Avatar
seastrike
thanks we have had some rain lately... and i drove it through a carwash on Friday. Good thought
Old May 16, 2015 | 07:43 AM
Sycoholic's Avatar
Sycoholic
Ghost wipers alone are usually remedied by replacing the multi function switch (turn signal switch). It's easy enough to do and takes about 10 minutes tops. The odometer issues sound like a water leak. That gem module will do some funky things when it gets wet. Do you have a Lund visor that could be leaking? Is your windshield leaking? If you got the time, pull down your pillar covers and drop the front of the headliner. Then have somebody soak it down with a hose while you're inside.
Old May 17, 2015 | 10:09 PM
04badford's Avatar
04badford
don't know about the wipers but here is a fix for the cluster black out.
https://www.ford-trucks.com/forums/1...lem-fixed.html
Old May 18, 2015 | 07:29 AM
seastrike's Avatar
seastrike
I think both may be windshield related. It has been dry this week and the problem has stopped. I think I will have a new windshield installed (it has a nice chip in it anyway) thank you for your reply
bhcoker
Nov 15, 2018 05:26 PM
12valveEx
Apr 3, 2018 10:56 PM
ALLISONTY44
Escape & Escape Hybrid
Mar 9, 2018 10:05 AM
JoeyCap
Feb 25, 2015 10:59 AM
ferret2
Jul 18, 2008 02:20 PM
