1995 E350 No Power
Old May 10, 2015 | 06:54 AM
jsikora's Avatar
jsikora
1995 E350 No Power
So i have no power on the ignition switch. In what little info i have found it appears the 2 yellow wires are 12 volt from the battery. No power here at all. I am also told it gets power from the under hood fuse block. There is a 60 amp maxi fuse labeled ignition and fuse is good. Does anyone have a wiring diagram showing if this is the actual location it gets power from ? Of course i can barley get my arm down to the block and cannot even see any wires...
Old May 12, 2015 | 11:26 PM
68Mercury250Ranger's Avatar
68Mercury250Ranger
those yellow wires might be fusable links attached at the power side of the starter solenoid. do you have batt voltage both sides of the fuse ? or did you do a visual inspection?
Old May 13, 2015 | 05:02 PM
jsikora's Avatar
jsikora
Been looking everyplace. I see no yellow wires leaving the starter. Only see a couple large cables leaving.
Old May 13, 2015 | 05:26 PM
68Mercury250Ranger
the "remote" solenoid/relay in behind the battery . might need to loosen the battery hold down for easier access.
did you have 12 volts each side of maxifuse ?
Old May 27, 2015 | 07:59 AM
alabamaredneckfla's Avatar
alabamaredneckfla
no power
I had a problem with no power. No lights, when ignition switch turn on the brake light went dim. The problem was the ignition control module. They don't tell you this in the manual, but if you look at the diagrams it shows that it goes through the ICM then to battery.
Old May 28, 2015 | 05:55 PM
jsikora's Avatar
jsikora
Thanks for the info. We actually just traded the vehicle in yesterday. Still not able to start it but its there problem now.
jbarendrecht85
Jul 22, 2016 01:39 PM
jsikora
May 10, 2015 11:41 AM
bsandman7
Apr 29, 2013 07:46 PM
rat49f6
Jul 10, 2012 09:38 AM
Pi150
Mar 2, 2004 08:21 PM
