1978 - 1996 Big Bronco
Servo?
Old Jul 28, 2003 | 12:54 AM
Seabisquit's Avatar
Seabisquit
Servo?
Where might I find the physical location of the cruise servo amplifier...Thanks.
Old Jul 28, 2003 | 01:57 AM
greystreak92's Avatar
greystreak92
Servo?
E-31 of the Haynes wiring diagrams on page 12-58. Otherwise, based solely on assumption from its location in the diagram, somewhere under the driver's side of the dash. Doesn't appear to be far from the column and pedals.
Old Jul 28, 2003 | 02:10 AM
Seabisquit's Avatar
Seabisquit
Servo?
Well, I'm not sure how you deduced that information, but I'll dang sure look for it there..thanks.
Old Aug 2, 2003 | 10:10 PM
steve83's Avatar
steve83
Servo?
There is no amplifier on '93-up trucks. That was only for the vacuum cruise system on the older ones. On yours, the whole cruise system is inside the servo, which is mounted near the L hood hinge.
Old Aug 2, 2003 | 11:44 PM
craterjoe's Avatar
craterjoe
Servo?
if it's all inside the servo, how difficult would it be to install c/c in a 96 bronc xl not origionally built with it? could the control switches be dash mounted?
Old Aug 2, 2003 | 11:53 PM
steve83's Avatar
steve83
Servo?
It's easier than that - the engine bay harness already has the connector for the servo, so get one with the cable to run to the throttle, swap a cruise horn pad onto your steering wheel, and plug it in. THAT'S ALL.
Old Aug 3, 2003 | 01:35 AM
Seabisquit's Avatar
Seabisquit
Servo?
Steve..after replacing the ring, and upon activating the cruise for the 1st time, it controlled for about 30 seconds and then shut off. The horn still works, but it will not pick-up the cruise control. I checked the sensor, and it seems fine (no obvious problems)...any ideas?
Old Aug 3, 2003 | 11:36 AM
steve83's Avatar
steve83
Servo?
You're gonna have to do more troubleshooting: is the cable still connected to the throttle? Is the brake pressure switch still sending power to the servo? Are the cruise buttons still sending signals? Which sensor are you saying is fine?
Old Aug 3, 2003 | 03:54 PM
craterjoe's Avatar
craterjoe
Servo?
swap a cruise horn pad onto your steering wheel, and plug it in. THAT'S ALL. [/B][/QUOTE]
would there be a prob regarding the air bag ?
Old Aug 3, 2003 | 05:14 PM
steve83's Avatar
steve83
Servo?
OOPS! You're right - I was thinking about the pre-'94 steering wheel. On '94-96, you need a cruise steering wheel, but the airbag will swap.
Old Aug 4, 2003 | 07:18 PM
Seabisquit's Avatar
Seabisquit
Servo?
Steve...I check the sensor going into the transfer case. The servo assembly itself looks okay (no arcing) and the cable is hooked up going to the TB..anything else?
Old Aug 4, 2003 | 09:57 PM
steve83's Avatar
steve83
Servo?
The stuff on the t-case has NOTHING to do with your cruise control - that went away in '92 (vacuum system). Yours runs STRICTLY off the ABS sensor in the rear axle, but that feeds thru the speedometer. Look in the 8.8" Axle album in my signature link and then check yours to see if it's loaded with metal shavings.
Old Aug 6, 2003 | 08:28 AM
Seabisquit's Avatar
Seabisquit
Servo?
Steve...I checked the ABS plug sensor as suggested, and found only a few (5) small shavings collected on the face of the sensor. I cleaned it and it had no effect on the cruise...sigh.
Old Aug 9, 2003 | 09:06 AM
Seabisquit's Avatar
Seabisquit
Servo?
Where is the pressure switch located on a '94? The Haynes does not show it...
Old Aug 10, 2003 | 11:18 PM
steve83's Avatar
steve83
Servo?
Top front of the brake master cylinder.
