stranded overheating
Old May 8, 2015 | 11:04 PM
BLACKHAWK_1989's Avatar
BLACKHAWK_1989
My radiator is overflowing as soon as i Shut off The engine, barely Made it off The freeway as it Got To The red, "ENGINE" indicator turned on. Drove 3 miles from last Stop To Let it cool. Loud bubling fizzing Sound and vibrating! Any advice appreciated To help me fix her and get back home.
1988 F-150 300 I6
Old May 8, 2015 | 11:53 PM
892504x4's Avatar
892504x4
Do you have water in your oil?
Old May 10, 2015 | 09:12 AM
GoFastGuy's Avatar
GoFastGuy
I'm pretty sure bubbling noise and pressure in the over flow is blown head gasket, take it with a grain of salt because I'm not there to actually look I suggest stop driving it to prevent any further damages
Old May 10, 2015 | 09:51 AM
bashby's Avatar
bashby
Could be as simple as a stuck thermostat
Old May 10, 2015 | 09:16 PM
BLACKHAWK_1989
Saturday morning I pulled The thermostat and it seemed To Run cooler than normal ot. Drove To repair Shop and Had thermostat replaced and coolant flushed. Drove 70 miles fine.
I started it up this morning and 5 min later it started To overheat. I Let it cool a couple min and it ran just fine. Later that day it Did The Same thing.
All gaskets Do leak oil on outside and rear Main seal oil/coolant.
Should i get it fixed or replace Motor?
$700-$1000 repairs all gaskets, block bolts & oil pump.
$1600-$2800 new or refurbished Motor.
Old May 10, 2015 | 09:33 PM
jaagen's Avatar
jaagen
How does the radiator look are the fins clogged or atleast have debris in them. Try flushing the radiator fins. It also the water pump might not be cooling enough or the internals might be going bad. It might also be there is a air pocket in the system.
Old May 10, 2015 | 09:45 PM
bb65f1004x4's Avatar
bb65f1004x4
Head gaskets are a real treat when not planned for. Go get yourself a $15 coolant "sniffer" from the auto parts store.
Old May 11, 2015 | 01:31 AM
BLACKHAWK_1989
I think that the motor is heating up faster then the thermostat. Perhaps the old thermostat seizing blew my head gasket? The radiator does not circulate until thermostat kicks in but heater works.
Kanfordman
Oct 14, 2021 03:14 PM
Socal250
41
Sep 10, 2014 01:46 AM
Shade
Apr 8, 2012 09:56 AM
Ford-Trucker84537
Jun 14, 2007 08:32 AM
rw84f150
Jun 13, 2005 03:39 PM
