Engine shut down
Old May 8, 2015 | 10:12 AM
d450heavy's Avatar
d450heavy
Engine shut down
Yesterday while driving to work my 06 6.0L shut down at 55 mph
No warning lights nothing. Towed to dealer and they aren't sure why it didn't go into limp mode.
Anybody have ideas? Dealer will diagnos next Monday but I'm very curious.
It was just lucky I was on a back country road when this happened. Lost all power steering, brakes etc
Old May 8, 2015 | 10:14 AM
mustang_309's Avatar
mustang_309
IPR valve or STC may have failed.
Old May 8, 2015 | 10:16 AM
d450heavy's Avatar
d450heavy
I don't know what either of those things are but it doesn't sound to expensive to repair then.
Motor would crank but no restart
Old May 8, 2015 | 11:09 AM
mustang_309
The IPR is what controls the ICP pressure and the STC fitting connects the HPOP discharge to the HPO branch tube to distribute HPO to the HPO rail on each cylinder head, the bad thing about letting the STC fitting fail is it can crack the rear engine cover which requires either the engine or transmission to be removed to replace the rear engine cover.
Old May 8, 2015 | 12:44 PM
KDAVID1's Avatar
KDAVID1
Neither are expensive (unless as mentioned above rear cover is cracked) as long as the dealer doesn't try to sell you a new HPOP lol. Easiest way to confirm HPO leak is do an air test.
On another question--do our trucks even have a limp mode?
Old May 8, 2015 | 01:03 PM
dannyboy950's Avatar
dannyboy950
A good question I can find no official ford documentation on limp mode.
However there is documentation on defueling which most people includeing myself call limp mode.
Old May 8, 2015 | 01:55 PM
KDAVID1's Avatar
KDAVID1
I would agree with that.
Old May 9, 2015 | 02:30 PM
tjguy's Avatar
tjguy
Funny, well not really, but I had the same thing happen today while at the light. for no reason the truck just turned off.
This is not the firs time it's happened and I am at a loss. The only difference here is unlike d450heavy, my truck started back up again and I was on my way to finish my errands. Mustang_309 pointed out it could be the IPR valve or/and the STC. in my case of being able to restart, could this be the IPR/STC valve or something electrical? FICM? d450heavy let us know what the dealer finds out, I am interested.
Old May 9, 2015 | 07:36 PM
04badford's Avatar
04badford
Did you pull any DTCs codes ?,the light don't have to be on to have a code stored, A Gauge will be Helpful Scan Gauge from Auto zone , you can get the Values for IPR, ICP, and post them up. Is the truck surging then stalling out or just dead petal? EGR come's to mind along with TPS .
Old May 9, 2015 | 07:39 PM
04badford's Avatar
04badford
Take a look at the ICP sensor if oil out the back of the sensor or in the connection, with the engine running do a wiggle test to the connection and wires , pinch at the grey clip holding the three wires together.
Old May 9, 2015 | 09:57 PM
tjguy's Avatar
tjguy
I just got a scan gauge 2, as soon as I can program those hexadecimal codes in there I will post. What values am I looking for on IPR and ICP? There where no codes when I used the scan feature.
Old May 9, 2015 | 10:04 PM
04badford's Avatar
04badford
Did you enter Xgauges in
Old May 11, 2015 | 09:47 PM
tjguy's Avatar
tjguy
OK, got the Xgauges set up and here are the gauges that I read on a cold engine at idle.
FMP 48.0
ICP 889
IPR 14.81%
SYC 1
looks like the IPR is a little low?
Old May 11, 2015 | 10:03 PM
04badford's Avatar
04badford
FMP 48.0
ICP 889
IPR 14.81%
SYC 1
your ICP is compensating for IPR , IPR at idle should be 24% test again warm and see the Values
Old May 11, 2015 | 10:12 PM
brandonrr's Avatar
brandonrr
FMP 48.0
ICP 889
IPR 14.81%
SYC 1
my IPR reads about 28% on a cold idle and around 22-23% on hot idle. i just got a scanguage myself last week and am fairly new to the 6.0 as of a month ago. i'm still learning, but that IPR reading doesn't seem right. just my .02. icp, ficm and sync seem good though.
